RUT956 - unable to get remote access to monitoring equipment
I have a RUT956 connected to a MetOne EBAM via the RS232 port.
I have network connection on the modem, and able to ping and get response on the required port.
Unable to access remote control function once I try to connect using MetOne software.
For troubleshooting purposes, we will require more sensitive information from your end, such as the troubleshoot file, which may contain passwords, public IP addresses, serial numbers, and such. To avoid leaking this information, we have sent you a form to fill out, which you will receive in your e-mail inbox that you have registered your account with in the forums. In the Ticket ID field of the form, please enter the ID of this thread, which is 18892.
