I have an H3C switch, a Teltonika rut956 and a PC. I want to configure the switch connected to the teltonika rut956 connected via console port and rs232 of teltonika. the pc is connected to the teltonika via the ethernet cable. how do i go about configuring the switch?
Adding the RUT956 actually adds an extra step to this setup. Yes, it can still be done using this configuration and by using a Linux package like minicom
or something similar. However, I would suggest doing it without the RUT956 by connecting the H3C switch directly to your PC/laptop for configuration. But remember, for configuring the H3C switch, you should contact its manufacturer or refer to the manual provided with the switch.
