Rut956 SMS commands
Ho necessità di creare un SMS per creare un comando di chiusura o apertura del replay per il teledistacco come richiesto da Enel. L’ SMS è il seguente: Distacco utenza POD a cui deve comandare l’apertura del relè interno per la disalimentazione dell’impianto collegato al POD. Questo SMS deve essere seguito da un SMS di risposta con la conferma del comando richiesto. Mi potete dire come configurare il Rut956? Grazie
Greetings, @Roberto ,
Thank you for reaching out! The RUT956 fully supports your use case. Here’s how to configure it:
  1. Go to Services → Mobile Utilities → SMS Utilities and edit the “Change I/O state” rule (default text: ioset) or create a custom rule with your preferred trigger text (e.g., YourRuleName).
  2. In the rule settings, set the Action to “Change I/O state”, select the relay output connected to your installation, and set the State to OFF (open) to cut power.
  3. Enable “Send response SMS” within the rule to automatically send a confirmation message back to the sender.
  4. For security, restrict the Allowed number(s) to sender number and set an Authorization method (e.g., by password). The SMS would then be sent as: YourPassword YourRuleName
Once configured, the router will open the relay and reply with a confirmation SMS as required.
Please let us know if you need any further assistance!
