Hello everyone, I couldn’t ping an RUT956 through wireguard tunnel. I’m connect a RUT956 to my server via wireguard. The following wireguard configuration is set on the router:
[instance]
Address = 10.252.1.14/32
PrivateKey = ...
MTU = 1300
[peer]
PublicKey = ...
PresharedKey = ...
AllowedIPs = 10.252.1.0/32
Endpoint = vpn.xxxxx.de:51820
PersistentKeepalive = 15
A connection is established:
wg show (server):
peer: ...
preshared key: (hidden)
endpoint: ...:15130
allowed ips: 10.252.1.14/32
latest handshake: 1 hour, 53 seconds ago
transfer: 26.77 KiB received, 10.47 KiB sent
wg show (RUT956):
peer: ...
endpoint: ...:51820
allowed ips: 10.252.1.0/32
latest handshake: 31 seconds ago
transfer: 35.02 KiB received, 4.35 KiB sent
persistent keepalive: every 15 seconds
Issue:
Even though the connection is established, I cannot ping the router (ping 10.252.1.14) from the server, nor can I ping the server (10.252.1.0) from the router.
I have already set all firewall rules to ACCEPT, but the issue persists.
I have already performed a factory reset, but the issue persists.
Additional Information:
- I have 23 other routers (both RUT955 and RUT956) connected to the same server via WireGuard, and ping works fine on all of them.
- The problematic router has the same firmware and identical configuration as the working ones.
- Despite this, it behaves differently and is not reachable via ping.
- An factory reset
Question:
Does anyone have an idea where else I should look?
