I installed a new RUT956 and tried to install Starlink on WAN connection, external Wifi connection and Modem connection all in Failover.
Connection to the RUT is always by Wifi Standard SSID RUT956-NNNN.
WPA is different my own.
Modem works perfect.
I installed travelmate for Wifi .Wifi wan can be found for example the starlink one with original Wifi Accespoint.
When I try to failover to Wifi Wan it alternates connect, disconnect all 3-4 minutes.
Same when I try to connect via Wan-Port directly on the Router.
I tried differnet Resets, Firmwareupdate and configurations.
I always try only one connection to be sure its not a failover problem, I disabled all other connections i only have one WAN working.
Still same Modem is ok, all others no Internet connection.
I have IP Adresses on Wan connection also DNS Servers, but no Internet, no way.
IS that a broken Device or some misconfigured Settings?
I trided different Configuration examples also the one wich configures the WiFi as Wan with travelmate Package.
Starlink worked fine with a cheap TP-Link Router instead of the origin one . I would use a 12V Installation so origin is not helpful for me.
I would configure Wan as WiFi ( Campground), Modem ( on the road) or Starlink if no Wifi and no LTE available.
Thank you for any helpful information.
Have you checked for any related logs in System → Maintenance → Troubleshoot by clicking Show next to system.log? If not, please review the logs, as they might help identify the cause of the issue.
If you need assistance reviewing the logs or require additional support, please let me know!
Thank You for answering
It seems there are some troubles with DNS or routing.
errors I found:
daemon.warn odhcpd[2822]: A default route is present but there is no public prefix on lan thus we don’t announce a default route!
I do not know wich Log you need to view.
Send you all what I downloaded.
Actually I Made a complete Factory reset and added only The WAN Input from Starlink.
No idea what to change.
Attached the Downloaded Troubleshoot files.
I have sent you a form to fill out. Once completed, I will contact you privately, and you will be able to send me a troubleshoot package.
For the ticket ID, please use “11915”.
I found a solution for the moment. Lan Cable between Starlink and RUT seems faulty. I tried after moved the router near to Starlink Ethernet and used a short cable, now it works. So I have to check at home what the problem coud be. Actually I am on road and do not have enough equippment to replace all with new one . Still strange why the cheap TP-Link worked and yours not. Thank You for your support, The way where I could find the logs helped me to go other way’s.
Good to hear that the issue seems to be resolved. Please let me know if you experience any issues with the WAN later.
