Hi All,
For test purpose, I’m using a RUT956 firmware RUT9M_R_00.07.08 with Usb key connected for the NMEA forwarding cache.
It’s an internal test, the RUT and my laptop are connected to the same switch, the GPS antenna is outside.
I would like to test the cache, for example, when the connection between the router and the laptop is down, the router still record the NMEA data in the cache then when the connection is up, the router sends all the NMEA record to the laptop until the newest datas.
My Laptop works as a server:
- UDP
- Port 8500
- data format NMEA
I receive the live data but not the data from the cache.
Do you know how it works?
Thanks.
