Rut956 - nat 1:1 vpn
Good morning everyone.
I have a difficulty with my RUT956:
My need is to reach a PLC via openvpn and static rule.
I configured the VPN and it works but when I create the static rule it doesn’t work…
The address of RUT956 is 192.168.140.3
My PLC address is 192.168.140.1
The address that the PLC must have on the VPN is 10.10.42.1
I tried to create the rule but unfortunately I can’t reach it
The connection of the RUT956 is via SIM Card
Thanks!
Hi maffich1,
May I know the purpose of configuring static routes on top of OpenVPN configuration? As you’ve mentioned above, PLC and RUT956 will be on the same subnet. Most likely, you will be configuring OpenVPN TAP which does not require virtual IP address. Kindly look into this documentation as a guide.
Thanks for the reply.
I configured it as TAP because my system is configured that way.
I already have 30 devices (eWon) configured this way and they work perfectly. I attach the photo of the ewon configuration.
Like OpenVPN I use pfsense.
I use a user and password as a method of accessing the VPN. I also attach the photo of the pfsense server configuration
Thank you
Hi @maffich1,
I don’t think anybody here wants to read eight pages of pfsense configuration.
Besides - this is a Teltonika forum, not a pfsense forum.
Please read the documentaion as @Janmiguel suggested.
Timelapse Admin
