RUT956 - MQTT issue with last firmware update
After an update of RUT956 (RUTM9M_R_00.07.07.2 → RUTM9M_R_00.07.11.2) and a reboot, I have a lot of problem with all MQTT connections by bridges.
2 bridges are configured for a redondancy connection (one per broker).
  • I need to force all parameters for each bridges if I want all bridges work again correctly.
Could you confirm that the Firmware version (RUTM9M_R_00.07.11.2) manage correctly all MQTT connection by bridges?
Thank you in advance for your support
– Additional observation –
After a “device reboot”, all two MQTT connections by bridges don’t work.
The “Require password” parameter go back to the “off” position.
There seems to be an interference between the parameters of the two bridges.
Best regards
