RUT956 I/O management via CLI/SSH
Hello everyone, I have a RUT956 with firmware version RUT9M_R_00.07.18. How can I manage the relay related to the input/output connector (pins 5 and 10) and, in general, all the I/Os via CLI or SSH? The examples shown on this page do not work: https://wiki.teltonika-networks.com/view/RUT956_Input/Output#Status.
The command ubus call ioman.gpio.din1 status returns: Command failed: Not found.
The only method I found to control the I/Os, and specifically to activate/deactivate the relay (pins 5 and 10), is the following:
/etc/init.d/ioman stop
gpioset gpiochip3 9=1
gpioset gpiochip3 9=0
/etc/init.d/ioman start
Thank you.
Greetings, tods,
Thank you for your question!
If you’re currently connected as admin, please note that this user account is intended only for access through the WebUI (web interface) and does not have sufficient permissions to execute commands in the CLI environment.
Instead, you’ll have to login to the SSH as the “root” user. To connect as root, simply open an SSH session to your device and log in using your root credentials. Once you’re logged in, you’ll have full access to execute the necessary commands.
For step-by-step instructions, you can follow this guide on how to connect to your device and access the CLI:
If you encounter any issues while connecting or running commands, feel free to share a screenshot of your SSH session or any error messages — I’ll be happy to help you troubleshoot further.
Vilius
