This was identified in development test version 08.424 and continues in FW 00.07.08
Executing the CLI command /usr/sbin/ntrip_client -d /dev/rs232 fails to start the NTRIP client
Response is
/usr/sbin/ntrip_client: unrecognized option: d
ntrip_client -s |config section| -D |debug level|
Stop the service
Note: | above is a replacement for < & > as contents between < & > were being stripped out
Has this command changed? Or an issue with this latest firmware?
