After last update the event juggler says it can not find the configuration (I had two events before). When I try to create a new event I get an error. In the log it says that I do not have permission. Any idea???
Could you please clarify what was the original firmware version and which version did you upgrade to? Software migration issues could have caused this.
Could you try reflashing the firmware via the bootloader menu?
Instructions are provided here: RUT956 Device Recovery Options - Teltonika Networks Wiki
Please note, that this will reset the device to factory default settings.
Did a factory reset and set up everything again and now it works ![]()
