RUT956 Disconnected from 4G network
Hello there. I’m using a few RUT956s with 4G connection and manual APN. Some of them disconnected from the network frequently and need to reboot to reconnect again. They are running with firmware version RUT9M_R_00.07.10/11. Any idea?
Thank you for reaching out.
To better understand the issue, could you please confirm if the mobile connection signal strength is constant and stable?
Additionally, when this issue occurs, could you try restarting the connection via the WebUI? You can do this by navigating to Status → Network → Restart Connection and see if that resolves the issue temporarily.
If this helps, but the issue persists, you can set up an Auto Reboot feature to automatically restart the mobile connection or reboot the modem. You can configure this by going to System → Maintenance → Auto Reboot.
Let me know how it goes, and feel free to reach out if you need further assistance.
Thanks Martynas, but the problem is, the connection can goes out in just a few hours after each reboot, so I don’t think it is really helpful.
btw, the signal is stable and strong.
Thank you for the update.
Since the connection issue persists despite a stable and strong signal, I’d like to investigate it further. I’ve sent you a form to fill out, for the ticket ID 10694 when submitting it. Once submitted, we will contact you privately to assist you with a more in-depth troubleshooting process.
Thanks Martynas, but I haven’t got the form yet?
