RUT956 - Data to Server issues
I have two MQTT instances in the “Data to server collections”.
  • “Startup message” intance : timer = None, Retry = off
  • “Signal RSSI message” intance : timer = Periode, Period = 60, Retry = off
Result, I find no MQTT message from “Startup message” intance.
But the “Startup message” intance is enable.
How does the instance behave if the “Timer” parameter is “None”?
If the “Timer” parameter is “None” with instance enabled, this instance run one time on reboot?
Thank you in advance for your support
