RUT956 + Bluetti AC200 MAX + Solar Power
Good morning,
I ask for advice on how to solve this problem:
I have a “Bluetti AC200 Max” power station installed in a house without a fixed electricity grid.
It is charged via solar panels (2 panels in series of 39Volt each)
The power station creates 230V to power the RUT956 + Video surveillance
Unfortunately on very dark days, the battery drops to 0% by turning off the powerstation. As a result, it turns off the RUT956 and the video surveillance.
To add further problems, the power station needs a MANUAL command on its display to be able to supply 230Volt again, by pressing the “AC ON” option.
I need to power the RUT956 with the voltage of the solar panels, so that when the sun returns, they can power the RUT control unit.
In this way, by installing an Android mobile phone and accessing remotely via teamViewer I should be able to give the “AC ON” command to the powerstation.
Can I coexist the power supply from the 4 PIN connector + power supply for example via the terminal blocks on the panels?
Without connecting the RUT956 I have no way to restart the entire system…
Thank you
Regarding powering the RUT956, you can use the 4-pin power socket, or the device can also be powered by an Ethernet cable via the LAN1 port. All the information about RUT956 powering options can be found on our wiki page: RUT956 Powering Options - Teltonika Networks Wiki.
