With the RUT956, is it possible to send an email when the battery voltage is under 11.4V or when it’s above 12 V ?
If yes, how can i do that ?
Hi anthony,
Yes, it is possible. There are a couple of things to configure such as Email User and I/O Juggler.
Once recipient is configured, go to I/O juggler directly. Under Actions, add an Instance → Type: Email. From this tab, you will insert the Subject, Email content, and email address then click Save and Apply.
Then, go to General, add new instance → Role: Analog Input (6,9). Enable the instance. Make sure that inside range is unchecked. In your use case, Min Voltage: 11.4, Max Voltage: 12, add Action: Action instance earlier then click Save and Apply.
With this configuration, if battery voltage is outside the range of 11.4 V to 12 V, it will send an email to the configured recipient.
Let me know if this helps.
Supporting Link: Input/Output
