RUT956 application installation/deployment options
Hello.
We’ve developed an IOT type application that runs and operates correctly on the RUT956.
The app is developed on a Ubuntu VM and cross compiled for the RUT956 target. I’ve developed a temporary installation routine that copies the application files to the RUT956 and it creates an enables a startup script in the /etc/init.d directory. This is fine for the testing scenario but not for final deployment.
Is there a simple approved way to deploy and application to the RUT956 using RMS or other approach? I read a bit about OPKG but that seems like overkill. From what I read, you need to use the RUTOS system development SDK to build the system and application before being able to use OPKG to package the app. Is this correct? Or, is there an OPKG option just to install application files and possibly run a setup install script to enable the startup script in the /etc/int.d directory?
Is there any Hello World tutorial examples of using the Teltonika RMS or other tools to create a simple installation?
Any suggestions appreciated..
Hello, @dpekin ,
Thank you for your question - happy to clarify a few things and gather a bit more detail before recommending the best deployment approach for your setup.
  1. Does OPKG require the full RUTOS SDK?
Not for deploying a custom app. You only need to package your application as a .ipk file. The SDK is only needed if you want to rebuild the entire firmware from scratch (e.g. to permanently embed the app or customise the WebUI). For your use case, packaging your binary and dependencies into a .ipk is sufficient.
For more information, please refer to this wiki article:
  1. Can RMS be used to deploy to one or many devices?
Yes - this is a well-supported workflow. You can upload your .ipk to RMS under Administration → Files, then create a Task Manager task group with two steps: one to push the file to the device (e.g. to /tmp/), and a second to run opkg install to install it. This can be applied to individual devices or in bulk.
For a detailed step-by-step guide, please refer to this forum topic:
  1. Are there examples to follow?
Yes. The RUTOS SDK Instruction page on the Teltonika Wiki includes a worked example of building and installing a custom application package, including manual .ipk installation steps. The community thread linked above also walks through the RMS Task Manager deployment path step by step.
Reference: RUTOS Software Development Kit (SDK) Instruction - Teltonika Networks Wiki
To recommend the most suitable approach for production, we have a few quick questions:
  1. Does your application consist of a single binary, or does it include additional files (libraries, config files, etc.) that need to be placed in specific locations?
  2. Are you cross-compiling with the official Teltonika RUTOS SDK or a standalone toolchain? This helps confirm runtime compatibility.
  3. How many devices are in your deployment, and will they have internet access during installation?
  4. Are your devices already enrolled in Teltonika RMS, and do you have an active subscription that includes Task Manager?
  5. Will you need to push application updates remotely on an ongoing basis, or is this a one-time installation?
Your answers will allow us to give you a clear, practical recommendation.
Thank you for the response. I’ve figured out how to use the task manager to do S/W installations on the RUT956. I’ve opted to use a tar-ball and installation script rather than OPKG. That seems to work fine. Thanks
