RUT955 - VPN Connection issue
Looking for some help. We have 10 RUT955 routers, i’ve recently updated 5 of the routers to version RUT9_R_00.07.06.20. Since the update I can no longer connect over VPN to a PTZ Hik Vision camera that was connected to it.
However the other 5 routers that weren’t updated can connect to them fine over VPN.
On the updated routers I can access the camera over port forward without any issues and I can also connect to other devices on the updated routers through vpn.
I can also ping the camera when the VPN is enabled.
The VPN is an IPSEC Lantolan VPN with IKEv2.
I have mirrored the firewall settings from a working RUT955 and made sure the zones match as well but still no joy.
For troubleshooting purposes, we will require more sensitive information from your end, such as your current configuration and the troubleshoot file, which may contain passwords, public IP addresses, serial numbers, and such. To avoid leaking this information, we have sent you a form to fill out, which you will receive in your e-mail inbox that you have registered your account with in the forums. In the Ticket ID field of the form, please enter the ID of this thread, which is 16155.
Ticket submitted
Unfortunately still no solution to this
