RUT955 SNMP Queries
I’m using RUT955 Routers on Firmware RUT9_R_00.07.04.5.
For our Monitoring via SNMP i would like to query:
  • Active SIM Card (expected output: Slot1 or Slot2)
  • Main Line (mobile or wired)
I can not find this in the Teltonika MIBs. I’m using OID: 1.3.6.1.4.1.48690
I was trying to use route tables with enumerations from standard linux mibs to determine the main line but had no success so far.
How could i query this via SNMP?
Pascal
SNMP variables for RUT955 can be found here: RUT955 SNMP - Teltonika Networks Wiki
As for determining which line is active, we currently do not have any OIDs for Failover, however, OID for interface state is available: .1.3.6.1.4.1.48690.11.2.1.3. It could be used to determine whether the WAN or Mobile interface is active or not.
When i’m doing an SNMP Walk on the RUT955 (RUT9_R_00.07.04.5) it’s ending at:
.1.3.6.1.4.1.48690.10.2.1.7.5
.1.3.6.1.4.1.48690.11.2.1.3 is not there. Is this released already?
It’s also not in the RUT955 SNMP Documentation.
Is the Teltonika Team regulary pushing the new MIBs to Solarwinds?
Solarwinds is only current up to 1.3.6.1.4.1.48690.9
