RUT955 RUT956 unable to connect to RMS (error log problem + contact support)
Events log issue should be resolvable like this:
  1. SSH into your router
  2. Go to log folder using command: cd /log/
  3. Run command: rm log.db
  4. Run command: /etc/init.d/eventslog restart
You need to know - and this explains the above - that log.db is NOT being touched/deleted by performing a factory reset. Hence doing it manually as written above.
