I open Mobile Hotspot for access the internet and then I setup the RUT955 to get the WIFI internet from Mobile to be the repeater.
I would like to use the internet via LAN port of RUT955.
Is it possible to use RUT955 as repeater?
If I understood you correctly, you want your RUT955 to receive internet from your mobile phone, and for the devices connected to your RUT955 to access the internet via your mobile network. Please correct me if I misunderstood.
If WiFi will be the only WAN source for your RUT955, you simply need to connect the RUT955 to your mobile phone’s hotspot. You can follow the instructions provided here: RUT955 WiFi Client Mode.
Once the RUT955 has an internet connection, any devices connected to its LAN will be able to use the internet from your mobile phone through the router.
Please let me know if you have any further questions or need assistance.
Hi Marija,
You are correct.
Thank you very much for your help.
Best regards
You’re welcome!
Please let me know if you need any further assistance with the setup.
