RUT955 OpenVPN tun client not working
When updating to the newest version (RUT9_R_00.07.06.11) we are not able to get the openvpn client to work.
The logging shows an error:
Wed May 29 13:58:41 2024 daemon.notice openvpn(fl)[6131]: net_route_v4_best_gw query: dst 0.0.0.0 Wed May 29 13:58:41 2024 daemon.notice openvpn(fl)[6131]: net_route_v4_best_gw result: via 0.0.0.0 dev qmimux0 Wed May 29 13:58:41 2024 daemon.warn openvpn(fl)[6131]: OpenVPN ROUTE: OpenVPN needs a gateway parameter for a --route option and no default was specified by either --route-gateway or --ifconfig options Wed May 29 13:58:41 2024 daemon.warn openvpn(fl)[6131]: OpenVPN ROUTE: failed to parse/resolve route for host/network: 10.8.0.1 Wed May 29 13:58:41 2024 daemon.notice openvpn(fl)[6131]: TUN/TAP device tun_c_fl opened Wed May 29 13:58:41 2024 daemon.notice openvpn(fl)[6131]: do_ifconfig, ipv4=0, ipv6=0 Wed May 29 13:58:41 2024 daemon.notice openvpn(fl)[6131]: /etc/openvpn/updown.sh tun_c_fl 1500 1622 init Wed May 29 13:58:42 2024 daemon.notice openvpn(fl)[6131]: Initialization Sequence Completed
It seems that the rut does not create the openvpn route properly. The same config does work fine on an older version. What can we do to resolve this issue?
Downgraded to RUT9_R_00.07.05.4 and it seems to work here fine. Clearly an issue in the newest firmware. The route doesn’t seem to be created.
