Witam. Czy w rut955 można odczytać wartość Napięcia Zasilania
Good afternoon,
To measure and monitor the voltage of the power supply (for example, a car battery or solar panel input), you need to use the analog input feature of the RUT955. The router is equipped with an analog input (ADC) that can measure voltages in the 0–24 V range. This allows you to monitor an external voltage source, such as your power supply, by connecting it to the appropriate input pins.
Connect the positive wire of the voltage you want to monitor to the analog input pin, and the negative wire to the ground pin.
Configure the analog input in the router’s WebUI to display the measured voltage.
The analog input is separate from the main power input; you must physically connect the voltage you wish to monitor to the analog input pins.
The analog input can measure up to 24 V. If your supply voltage exceeds this, you must use a voltage divider to avoid damaging the router.
The analog input does not automatically measure the voltage at the power input; you must wire the supply voltage to the analog input pins to monitor it.
Arturas
