RUT955 not sending data via LAN
i have around 70 RUT955 routers and recently I started observing weird behaviour.
We using those routers to give mobile connection to self-service kiosks.
RUT955 with Simcard → connected via LAN to PC, providing internet connection.
I have started observing, that on some machines the web-based GUI is not loading, however the RUT955 was receiving bandwidth (seen it via RMS)
So I went to machine and connected to PC and router.
My observation is:
Ping from router to 8.8.8.8 - is working
ping from PC to 8.8.8.8 - not working
tracert from PC to 8.8.8.8 not working (not even one jump)
ping from PC to router is working
FW. 07.05.4
I have also available a troubleshooting file
What is the output of:
ip -4 rule show
on the router ?
It wont let me go to CLI, because I don’t have some sort of certificate.
GUI CLI SAYS “TO ACCESS CLI YOU NEED TO ADD CERTIFICATE ACCEPTION TO YOUR BROWSER!”
Could you try with ssh (putty, openssh …) ?
Ok, i was using the GUI name/password for device CLI from RMS. after used /root / pwd is working.
This is the output for
IP -4 rule show
     Teltonika RUT9 series 2024
   Device:     RUT955
   Kernel:     5.4.259
   Firmware:   RUT9_R_00.07.06.1
   Build:      0f141b8753
   Build date: 2024-01-02 10:11:13
root@Teltonika-RUT955:~# ip -4 rule show
0:      from all lookup local
1002:   from all iif qmimux0 lookup 2
2002:   from all fwmark 0x200/0x3f00 lookup 2
2061:   from all fwmark 0x3d00/0x3f00 blackhole
2062:   from all fwmark 0x3e00/0x3f00 unreachable
3002:   from all fwmark 0x200/0x3f00 unreachable
32766:  from all lookup main
32767:  from all lookup default
Try this command:
ip -4 rule delete $(ip -4 rule show | grep 2062 | cut -d: -f 2)
and restart the ping.
What is the default route on the PC ?
I was able to find another router with the issue:
In this case, when it is in this state, the IP -4 rule show is not working
   |  _ \ _   _| |_ / _ \/ ___|
   | |_) | | | | __| | | \___ \
   |  _ <| |_| | |_| |_| |___) |
   |_| \_\\__,_|\__|\___/|____/
   Device:     RUT955
   Kernel:     5.4.259
   Build:      0f141b8753
root@Teltonika-RUT955:~# IP -4 rule show
-ash: IP: not found
-ash: IP: not found
-ash: IP: not found
root@Teltonika-RUT955:~# ip -4 rule delete $(ip -4 rule show | grep 2062 | cut -d: -f 2)
"ip rule del" requires arguments.
output from Ifconfig:
root@Teltonika-RUT955:~# ifconfig
br-lan    Link encap:Ethernet  HWaddr 00:1E:42:2E:DB:E4
          inet addr:192.168.1.1  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::21e:42ff:fe2e:dbe4/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:45533 errors:0 dropped:0 overruns:0 frame:0
          TX packets:13934 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:3800859 (3.6 MiB)  TX bytes:3300622 (3.1 MiB)
eth0      Link encap:Ethernet  HWaddr 00:1E:42:2E:DB:E4
          RX packets:45569 errors:0 dropped:0 overruns:0 frame:0
          TX packets:13942 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:4622757 (4.4 MiB)  TX bytes:3357254 (3.2 MiB)
          Interrupt:5
eth0.1    Link encap:Ethernet  HWaddr 00:1E:42:2E:DB:E4
          RX packets:45569 errors:0 dropped:36 overruns:0 frame:0
          RX bytes:3802515 (3.6 MiB)  TX bytes:3300622 (3.1 MiB)
eth1      Link encap:Ethernet  HWaddr 00:1E:42:2E:DB:E5
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
          Interrupt:4
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:522 errors:0 dropped:0 overruns:0 frame:0
          TX packets:522 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:50944 (49.7 KiB)  TX bytes:50944 (49.7 KiB)
qmimux0   Link encap:UNSPEC  HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
          inet addr:10.151.119.233  P-t-P:10.151.119.233  Mask:255.255.255.255
          inet6 addr: fe80::9c73:83e8:ffff:6e48/64 Scope:Link
          UP POINTOPOINT RUNNING NOARP MULTICAST  MTU:1500  Metric:1
          RX packets:12138 errors:0 dropped:0 overruns:0 frame:0
          TX packets:15015 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:3201052 (3.0 MiB)  TX bytes:1370331 (1.3 MiB)
wlan0     Link encap:Ethernet  HWaddr 00:1E:42:2E:DB:E6
          inet6 addr: fe80::21e:42ff:fe2e:dbe6/64 Scope:Link
          TX packets:1188 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:277873 (271.3 KiB)
wwan0     Link encap:Ethernet  HWaddr D6:A2:8B:4E:D1:E4
          inet6 addr: fe80::d4a2:8bff:fe4e:d1e4/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:4096  Metric:1
          RX packets:11223 errors:0 dropped:11223 overruns:0 frame:0
          TX packets:12270 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:3143026 (2.9 MiB)  TX bytes:1426729 (1.3 MiB)
output from GUI router:
DHCP Leases.
Hostname	             IP Address	       MAC Address	             Leasetime Remaining
H-0QAS9S483J001     192.168.1.201   00:E0:67:26:70:1C.        11:51:33
However, the ping from trouter can’t reach to the computer:
root@Teltonika-RUT955:~# ping 192.168.1.201
PING 192.168.1.201 (192.168.1.201): 56 data bytes
^C
--- 192.168.1.201 ping statistics ---
144 packets transmitted, 0 packets received, 100% packet loss
netstat does not see the computer:
root@Teltonika-RUT955:~# netstat -r
Kernel IP routing table
Destination     Gateway         Genmask         Flags   MSS Window  irtt Iface
default         *               0.0.0.0         U         0 0          0 qmimux0
10.151.119.233  *               255.255.255.255 UH        0 0          0 qmimux0
192.168.1.0     *               255.255.255.0   U         0 0          0 br-lan
however, ping to google is working:
root@Teltonika-RUT955:~# ping to google
PING www.google.com (142.250.181.164): 56 data bytes
64 bytes from 142.250.181.164: seq=0 ttl=114 time=47.902 ms
64 bytes from 142.250.181.164: seq=1 ttl=114 time=64.539 ms
64 bytes from 142.250.181.164: seq=2 ttl=114 time=64.213 ms
64 bytes from 142.250.181.164: seq=3 ttl=114 time=63.782 ms
64 bytes from 142.250.181.164: seq=4 ttl=114 time=46.185 ms
^C
--- www.google ping statistics ---
5 packets transmitted, 5 packets received, 0% packet loss
round-trip min/avg/max = 46.185/57.324/64.539 ms
Linux is case-sensitive, “ip” is in lowercase.
   ____        _    ___  ____
   Device:     RUT955
   Kernel:     5.4.259
   Build:      0f141b8753
1001:   from all iif qmimux0 lookup 1
2001:   from all fwmark 0x100/0x3f00 lookup 1
3001:   from all fwmark 0x100/0x3f00 unreachable
ifconfig:
br-lan    Link encap:Ethernet  HWaddr 00:1E:42:32:D0:24
          inet6 addr: fe80::21e:42ff:fe32:d024/64 Scope:Link
          RX packets:4457 errors:0 dropped:0 overruns:0 frame:0
          TX packets:5169 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:298212 (291.2 KiB)  TX bytes:4634759 (4.4 MiB)
eth0      Link encap:Ethernet  HWaddr 00:1E:42:32:D0:24
          RX packets:4461 errors:0 dropped:0 overruns:0 frame:0
          TX packets:5177 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:378694 (369.8 KiB)  TX bytes:4656331 (4.4 MiB)
          Interrupt:5
eth0.1    Link encap:Ethernet  HWaddr 00:1E:42:32:D0:24
          RX packets:4461 errors:0 dropped:4 overruns:0 frame:0
          RX bytes:298396 (291.4 KiB)  TX bytes:4634759 (4.4 MiB)
eth1      Link encap:Ethernet  HWaddr 00:1E:42:32:D0:25
          Interrupt:4
          RX packets:242 errors:0 dropped:0 overruns:0 frame:0
          TX packets:242 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:24814 (24.2 KiB)  TX bytes:24814 (24.2 KiB)
          inet addr:10.145.41.222  P-t-P:10.145.41.222  Mask:255.255.255.255
          inet6 addr: fe80::6d66:85bf:99e8:33ad/64 Scope:Link
          RX packets:4887 errors:0 dropped:0 overruns:0 frame:0
          TX packets:3767 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:4611775 (4.3 MiB)  TX bytes:347416 (339.2 KiB)
wlan0     Link encap:Ethernet  HWaddr 00:1E:42:32:D0:26
          inet6 addr: fe80::21e:42ff:fe32:d026/64 Scope:Link
          TX packets:222 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:60866 (59.4 KiB)
wwan0     Link encap:Ethernet  HWaddr EA:78:76:96:39:EC
          inet6 addr: fe80::e878:76ff:fe96:39ec/64 Scope:Link
          RX packets:3278 errors:0 dropped:3278 overruns:0 frame:0
          TX packets:2211 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:4599664 (4.3 MiB)  TX bytes:324986 (317.3 KiB)
Does the ping to 8.8.8.8 from the PC works if the rule 2062 is deleted ?
Here are some steps you can take to troubleshoot and identify the issue:
  • Make sure that failover is disabled.
  • Check the firewall settings on both the router and the PC to ensure that they are not blocking outbound traffic.
  • Make sure the default gateway is set to the IP address of the RUT955 router.
  • As you mentioned, you are using firmware version 07.05.4. Try to update to the latest firmware RUT955 Firmware Downloads - Teltonika Networks Wiki it can help solve the issue.
Marija S.
> Build:      0f141b8753
> root@Teltonika-RUT955:~# ping 192.168.1.235
> PING 192.168.1.235 (192.168.1.235): 56 data bytes
> ^C
> --- 192.168.1.235 ping statistics ---
> 10 packets transmitted, 0 packets received, 100% packet loss
> ^C
> 55 packets transmitted, 0 packets received, 100% packet loss
Happened again. I tried to delete the rule 2062 and tried the ping again. Did not work. Only thing what helps at this stage is reboot router.
Blockquote Marija
I have updated the FW to : * Firmware version RUT9_R_00.07.06.1 couple of days ago.
Failover is turned off from beginning.
In the topology network it does not see any devices connected:
Hostname (Vendor) IP address MAC address Type Interface
There are no devices
on the all 68 PC we use the same Windows image with default gateway for the routers.
I have setup autoreboot everyday at 2:00 AM
This happened after the reboot.
5696 2024-01-20 02:04:26 Network Operator Connected to Vodafone OM operator (internal modem)
5695 2024-01-20 02:04:26 Network Type Joined LTE network (internal modem)
5694 2024-01-20 02:04:26 Mobile Data Mobile data connected (internal modem)
5693 2024-01-20 02:03:48 Failover WAN (mob1s1a1) is down, no more backups to switch
5692 2024-01-20 02:02:20 Failover Switched to main WAN (mob1s1a1)
5691 2024-01-20 02:02:07 DHCP Leased 192.168.1.235 IP address for client 00:e0:67:27:53:1c - H-8QPHN2NFNI3NS in LAN
5690 2024-01-20 02:01:56 IP Block ip_blockd service is enabled, initialized firewall rules
5689 2024-01-20 02:01:50 Switch Events Port speed for port LAN1 changed to 100 baseT
5688 2024-01-20 02:01:50 Switch Events Port link state of port LAN1 changed to UP
i can see this messages in Event logs:
5707 2024-01-20 11:09:43 Switch Events Port link state of port LAN1 changed to UP
5706 2024-01-20 11:09:36 Switch Events Port link state of port LAN1 changed to DOWN
5705 2024-01-20 04:33:13 Switch Events Port speed for port LAN1 changed to 100 baseT
5704 2024-01-20 04:33:13 Switch Events Port link state of port LAN1 changed to UP
5703 2024-01-20 04:33:11 Switch Events Port link state of port LAN1 changed to DOWN
5702 2024-01-20 04:32:54 Switch Events Port speed for port LAN1 changed to 100 baseT
5701 2024-01-20 04:32:54 Switch Events Port link state of port LAN1 changed to UP
5700 2024-01-20 04:32:53 Switch Events Port link state of port LAN1 changed to DOWN
5699 2024-01-20 04:32:52 Switch Events Port speed for port LAN1 changed to 10 baseT
5698 2024-01-20 04:32:52 Switch Events Port link state of port LAN1 changed to UP
5697 2024-01-20 04:32:49 Switch Events Port link state of port LAN1 changed to DOWN
Here are some options you can try:
  1. Utilize a different LAN (end) device.
  2. Temporarily disable the firewall for testing purposes using the command /etc/init.d/firewall stop (Don’t forget to re-enable it later with the command /etc/init.d/firewall start)
  3. Please provide the output of ipconfig /all command, specifically for the interface connected to the router.
  4. Share details of your PC’s default route information please, specifically the part shown in the screenshot. You can obtain this information using the command ROUTE PRINT
  5. Conduct a packet capture using Wireshark to verify if you are indeed not receiving any packets.
Marija
