I just tried to add a Teltonika RUT955 to the RMS portal. Unfortunately, this is not possible. The portal indicates that a additional authentication is required. How can I implement this? I tried inserting the code from the portal into the router and manually activated the connection. However, the router does not connect and always shows a license error.
I have sent you a form to complete. Once you have filled it out, I will contact you privately regarding this issue. For the ticket ID, please use “11745”.
