Rut955, tried to download modem firmware update from server but just get message “ Modem update failed, Firmware update verify was unsuccessful”. Can’t find the file in available downloads to try that update route. Any help gratefully received.
Hi…
Can you share the RutOS version, that you have today at your router?
Hi Marcelo,
Thank you for the quick response
Version installed RUT9_R_00.07.06.17
Chris
Hi Marcelo,
Just copied this from the Router.
- Firmware version
RUT9_R_00.07.06.17
- Firmware build date
2025-01-06 07:09:12
- Internal modem firmware version
EC25EUGAR06A07M4G_01.001.01.001
- Kernel version
5.4.259
Last version for RUT955.
So… I can just guess.
1 - maybe you getting a corrupt file transfer, because the cpu limitation.
2 - Don’t have enough free space to unpack the file at internal flash
3 - Your internet are getting some break of file? So… You need to keep trying to download it?
But… because I am not a Teltonika engineer… I cannot give you a final word, about what is happen with the modem update.
Are there some reason to do this update?
I keep my with the original modem firmware, because I do not want to loose it, case of something goes wrong, during the update of modem firmware.
Ok will try again with the download. Only reason for updating is that it’s flagged as being an available update when I log on to the router.
Try…
Just leave your PC/MAC/LINUX connected at the router and keep it away from other simultaneos connections… like other PCs or network devices. Just few minutes, before and after the download of the modem firmware.
Ok will do thanks
Let me know how the modem upgrade goes or if you need any further assistance. Additionally, after upgrading the modem, it’s recommended to reboot the router to ensure all changes take effect properly.
Hi Martynas,
Followed previous advice but still unable to download the modem firmware update.
Is it possible to have a link to download the update and try the load from file option?
Chris
Thank you for your update.
What is the primary internet source when you’re trying to install the modem update through WebUI? If possible, could you try installing it using a wired WAN connection as the primary source?
If that doesn’t help and you need further assistance with the upgrade, I’ve sent you a form to fill out. Please use 12132 as the ticket ID when completing it. Once submitted, we’ll contact you privately with further assistance regarding the modem upgrade.
Hi, finally resolved the issue of not being to update the 955 router modem firmware. Factory reset the router then the update downloaded no problem.
I should have done this sooner, but never mind every day is a learning day!
Anyway, thank you for the initial support to my tech issue.
Best regards
Chris
Same problem when updating the modem firmware.
After succesful firmware upgrade to RUT9_R_00.07.06.14, a modem firmware update from server failed.
Also a full factory reset (as used by Rogerscr) did not solve the modem firmware issue.
Actual modem firmware version: EC25EUGAR06A07M4G_01.001.01.001
I used a wired WAN connection for internet access.
So: I have two questions:
- What is the need for this latest modem firmware update (in relation with the latest RUT955 firmware?)
- How can I get the modem firmware as a file (and perform a firmware update with a local file)
Same problem for me, RUT955 with RUT9_R_00.07.06.17
Factory feset (and deleting the log files) did not help, i tried downloading by Mobile and WiFi, cable WAN is currently not easy to test - but seems to work without the update. I would strongly recommend a factory reset after the failed update because it seems unreliable after the failed update.
