Hello Ivo,
Thank you for your responses.
I can see that the RUT955 does not seem to be communicating via DHCP at least so far.
If the LAN port LED light is blinking green when you plug your cable in we can try statically giving your Win 11 PC a 192.168.1.2 255.255.255.0 ip and see if you can ping the 192.168.1.1
Also can you confirm after you reset the device, if you connected via Wifi were you able to go through the Setup Wizard again?
If you could provide screenshots after following these steps:
On your Win 11 Computer please open your Control Panel → Network and Internet → Network Connections.
Make sure all other interfaces are disabled, besides your ethernet connecting to the RUT955, by right clicking on them and selecting ‘Disable’.
Right click on your Ethernet interface that is connected to the RUT955, select Properties. Click on ‘Internet Protocol Version 4 (TCP/IPv4)’ → Properties.
Select ‘Use the following IP address’.
For IP address: 192.168.1.2
For Subnet mask: 255.255.255.0
Default gateway: 192.168.1.1
Please take a screenshot of the config here.
Select ‘OK’
Select ‘Close’ on the ‘Ethernet Properties’ window for changes to take effect.
Hit Winkey + R → This should open a search bar. Type in ‘cmd’ & hit Enter.
Or simply type in the Windows search bar ‘cmd’ and hit Enter
See if you can ping 192.168.1.1
Screenshot your results.
If you do not get any ping returns repeat the same steps as before, but this time give yourself a 192.168.1.10 IP.
I want to try this 1st in case there is something wrong with DHCP between the RUT device & your Win 11 device.
The next thing we can try is downgrading the Firmware. BUT I would only try this after 1st attempting the 1st method I provided.
This method may still not work if there is physical problem with the LAN ports.
Before that can you confirm what Firmware Version you are currently at?
If you are not on RUT9_R_00.07.06.11 I would recommend upgrading to this newest via Wifi or with your SIM card, before we try downgrading.
CAUTION: This method uses our emergency bootloader to downgrade the Firmware. If power is lost to the devices or the connection is lost between the Win PC & the RUT955 it could brick the device.
BEFORE starting please confirm you have a stable power source to both your RUT955 & Windows PC.
This will take up to 10-20 minutes to finish, please make sure your Windows PC does not go into sleep mode.
Follow the instructions listed here on our Wiki (link below).
When downloading the firmware for your RUT955, do NOT go lower than a Single version available.
For example Current Version: RUT9_R_00.07.06.11
I would not go lower than RUT9_R_00.07.06.10
And you will want to access the Firmware upgrade URL 192.168.1.1/index.html
NOT the /uboot.html
https://wiki.teltonika-networks.com/view/Bootloader_menu
After a successful Firmware downgrade I would repeat our previous troubleshooting steps to check for connectivity.
I can provide further assistance afterwards.
