My RUT955 stopped working suddenly, no lights on. The power led is off. Resetting does not help. I measured the power voltage inside the box, it was 9.32. It is about 2 years old but not much used. Can I do something else but buy a new one?
Try to do the following:
First of all, set a static IP address on your computer‘s network interface (e.g. 192.168.1.10)
Use private/incognito Web browser window with cleared/disabled cache
Power on the device while holding the reset button, and keep holding the reset button for 5 seconds after the device is powered on.
The router’s LEDs will start to flash rapidly, indicating that the bootloader’s web server (used for recovery) has started.
Access router via a different web browser page - http://192.168.1.1/index.html
Upload new router’s firmware (which firmware to use depends on the device’s hardware. Older devices require older LEGACY firmware, while newer ones - RUTOS firmware):
Wait a few minutes. The router‘s LEDs should stop flashing. Only the LED with the LAN cable connected to that port should be active (and some signal strength LEDs)
Try to access the router via a web browser at http://192.168.1.1
Hello @jekutin,
Please let me know if your issue has been resolved or if you still need any assistance.
