RUT955 boot loader stuck on v1.0.0
I have successfully fixed a couple of Teltonika RUT955 devices via firmware updates, but this one specific unit is giving me a really hard time. I’ve tried everything possible, but it won’t update the bootloader from version 1.0.0, no matter which firmware I use.
Firmware version:
RUT9XX_R_00.06.09.5
Firmware build date:
2023-05-19, 05:46:01
Kernel version:
3.18.44
Bootloader version:
1.0.0 – Update needed [Download]
Please advise what to do.
Yes, I tried updating the firmware from 192.168.1.1/index.html and the update completed, but the bootloader still did not change.
If you’ve successfully updated the firmware, may I ask why you still want to update the bootloader?
Are you having trouble updating to the non-legacy version of the firmware?
Hi Justinas
Because RUT955 is not working properly. I have it on cellular, and after every reboot of Teltonika i have to re do the cellular settings to start working. I know i resolve this once before with updating it to new UI (but, it had bootloader v3 on it already). This specific rut955 is also not showing signal strenght with led indicators, but it is nonstop red led indicator…
What else do you recommend then, if not updating the router?
For troubleshooting purposes, we will require more sensitive information from your end, such as the troubleshoot file, which may contain passwords, public IP addresses, serial numbers, and such. To avoid leaking this information, we have sent you a form to fill out, which you will receive in your e-mail inbox that you have registered your account with in the forums. In the Ticket ID field of the form, please enter the ID of this thread, which is 16595.
