RUT955,956 etc post/Get
Now that the POST/GET function is no longer available in the new firmware, what is the next possible method to toggle Wi-Fi on and off via local Ethernet? Currently, we’ve been controlling a relay connected to a RUT956 over Ethernet, and from there we’ve wired it to short or open Digital Input 1, which we’ve used to turn Wi-Fi on or off. It would be important to find a working solution, since we have over 200 RUT boxes deployed worldwide.
Good afternoon,
You can control your device with API functionality. More information : https://developers.teltonika-networks.com/
You can use CURL commands, API calls via the Postman app, write a custom script.
Arturas
