RUT951 Wireguard / Netbird
Hi!
On RUT951 is there whay way to get Docker working?
The 951 has support for wireguard, but for me it seams that it only supports wireguard in that way that it acts like a server and creates kyes and i cant add it like a peer to an existing wireguard server. Am i right in my assumptions?
I have tested Netbird witch is also based on wireguard, is there any way to get 951 to work with netbird?
/Peter
Not really, the device itself has too little memory & resources overall to run Docker. We have a configuration example for our RUTC series router: Docker Configuration Example - Teltonika Networks Wiki
Teltonika devices can act both as a server and as a client. Perhaps you could view these Wiki configuration examples so things are a bit clearer:
We haven’t tested functionality between Teltonika devices and Netbird, but there shouldn’t be an issue as Netbird operates the same way as a simple Wireguard VPN, as it is Wireguard-based, according to my Google search.
