Hi!
Below are the output from the iwinfo commands. The dmesg output is included at the end.
The “timed out” messages at the end of dmesg are generated each time I run “iwinfo wlan0 scan”.
root@Teltonika-RUT951:~# iwinfo wlan0 scan
No scan results
root@Teltonika-RUT951:~# iwinfo wlan0 assoclist
No station connected
root@Teltonika-RUT951:~# iwinfo wlan0-1 assoclist
The router is at a remote cottage that I rent out and wlan0-1 is the
guest network. It seems that the WiFi freeze happens when the guests
arrive back home (or new guests arrive) and their phones try to
reconnect to the guest network. On the wlan0 network I have an air
heat pump and a “Smart Life” temperature sensor connected.
Let me know if there are other diagnostic commands that I can run.
The last guest has left so I cannot power cycle the unit until I go
there myself next month.
[ 0.000000] Linux version 5.4.229 (app@runner-ffjpezdj-project-352-concurrent-0) (gcc version 8.4.0 (OpenWrt GCC 8.4.0 r16279-5cc0535800)) #0 Mon Jul 24 11:59:22 2023
[ 0.000000] Board has DDR2
[ 0.000000] Analog PMU set to hw control
[ 0.000000] Digital PMU set to hw control
[ 0.000000] SoC Type: MediaTek MT7628AN ver:1 eco:2
[ 0.000000] printk: bootconsole [early0] enabled
[ 0.000000] CPU0 revision is: 00019655 (MIPS 24KEc)
[ 0.000000] MIPS: machine is Teltonika RUT9M
[ 0.000000] Initrd not found or empty - disabling initrd
[ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[ 0.000000] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000000000000-0x0000000007ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x0000000007ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000007ffffff]
[ 0.000000] On node 0 totalpages: 32768
[ 0.000000] Normal zone: 256 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 32768 pages, LIFO batch:7
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 32512
[ 0.000000] Kernel command line: console=ttyS0,115200 rootfstype=squashfs,jffs2
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.000000] Writing ErrCtl register=0005565b
[ 0.000000] Readback ErrCtl register=0005565b
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 123904K/131072K available (3796K kernel code, 173K rwdata, 552K rodata, 1232K init, 188K bss, 7168K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS: 256
[ 0.000000] intc: using register map from devicetree
[ 0.000000] CPU Clock: 580MHz
[ 0.000000] timer_probe: no matching timers found
[ 0.000000] clocksource: MIPS: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6590553264 ns
[ 0.000013] sched_clock: 32 bits at 290MHz, resolution 3ns, wraps every 7405115902ns
[ 0.008008] Calibrating delay loop... 385.02 BogoMIPS (lpj=770048)
[ 0.046204] pid_max: default: 32768 minimum: 301
[ 0.051058] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.058409] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.073114] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.082977] futex hash table entries: 256 (order: -1, 3072 bytes, linear)
[ 0.089872] pinctrl core: initialized pinctrl subsystem
[ 0.097018] NET: Registered protocol family 16
[ 0.207878] mt7620-pci 10140000.pcie: Port 0 N_FTS = 1b105000
[ 0.363269] mt7620-pci 10140000.pcie: PCIE0 no card, disable it(RST&CLK)
[ 0.370026] mt7620-pci: probe of 10140000.pcie failed with error -1
[ 0.403858] workqueue: max_active 576 requested for napi_workq is out of range, clamping between 1 and 512
[ 0.417595] clocksource: Switched to clocksource MIPS
[ 0.424081] NET: Registered protocol family 2
[ 0.428849] IP idents hash table entries: 2048 (order: 2, 16384 bytes, linear)
[ 0.437168] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 0.445677] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.453401] TCP bind hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.460521] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.467098] UDP hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.473715] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.481077] NET: Registered protocol family 1
[ 0.485503] PCI: CLS 0 bytes, default 32
[ 0.494901] workingset: timestamp_bits=30 max_order=15 bucket_order=0
[ 0.509355] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.515243] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.542626] mt7621_gpio 10000600.gpio: registering 32 gpios
[ 0.548604] mt7621_gpio 10000600.gpio: registering 32 gpios
[ 0.554549] mt7621_gpio 10000600.gpio: registering 32 gpios
[ 0.560540] Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled
[ 0.568311] printk: console [ttyS0] disabled
[ 0.572718] 10000c00.uartlite: ttyS0 at MMIO 0x10000c00 (irq = 28, base_baud = 2500000) is a 16550A
[ 0.581859] printk: console [ttyS0] enabled
[ 0.590275] printk: bootconsole [early0] disabled
[ 0.600655] 10000d00.uart1: ttyS1 at MMIO 0x10000d00 (irq = 29, base_baud = 2500000) is a 16550A
[ 0.611210] spi-mt7621 10000b00.spi: sys_freq: 193333333
[ 0.635299] spi-nor spi0.0: w25q128 (16384 Kbytes)
[ 0.640260] 5 fixed-partitions partitions found on MTD device spi0.0
[ 0.646714] Creating 5 MTD partitions on "spi0.0":
[ 0.651598] 0x000000000000-0x000000020000 : "u-boot"
[ 0.657854] 0x000000020000-0x000000030000 : "config"
[ 0.663979] 0x000000030000-0x000000060000 : "factory"
[ 0.670344] 0x000000060000-0x000000f70000 : "firmware"
[ 0.680535] 2 uimage-fw partitions found on MTD device firmware
[ 0.686627] Creating 2 MTD partitions on "firmware":
[ 0.691690] 0x000000000000-0x000000180000 : "kernel"
[ 0.697885] 0x000000180000-0x000000f10000 : "rootfs"
[ 0.703974] mtd: device 5 (rootfs) set to be root filesystem
[ 0.711795] 1 squashfs-split partitions found on MTD device rootfs
[ 0.718167] 0x000000c00000-0x000000f10000 : "rootfs_data"
[ 0.724773] 0x000000f70000-0x000001000000 : "event-log"
[ 0.954595] mtk_soc_eth 10100000.ethernet eth0: mediatek frame engine at 0xb0100000, irq 5
[ 0.965240] NET: Registered protocol family 10
[ 0.974998] Segment Routing with IPv6
[ 0.978977] NET: Registered protocol family 17
[ 0.983573] 8021q: 802.1Q VLAN Support v1.8
[ 1.000123] VFS: Mounted root (squashfs filesystem) readonly on device 31:5.
[ 1.014422] Freeing unused kernel memory: 1232K
[ 1.019047] This architecture does not have kernel memory protection.
[ 1.025585] Run /sbin/init as init process
[ 1.839546] init: Console is alive
[ 1.843437] init: - watchdog -
[ 5.163511] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[ 5.358290] usbcore: registered new interface driver usbfs
[ 5.364021] usbcore: registered new interface driver hub
[ 5.369601] usbcore: registered new device driver usb
[ 5.566838] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 5.583463] SCSI subsystem initialized
[ 5.594644] ehci-fsl: Freescale EHCI Host controller driver
[ 5.603054] ehci-platform: EHCI generic platform driver
[ 5.718620] phy phy-10120000.usbphy.0: remote usb device wakeup disabled
[ 5.725440] phy phy-10120000.usbphy.0: UTMI 16bit 30MHz
[ 5.730754] ehci-platform 101c0000.ehci: EHCI Host Controller
[ 5.736637] ehci-platform 101c0000.ehci: new USB bus registered, assigned bus number 1
[ 5.744819] ehci-platform 101c0000.ehci: irq 26, io mem 0x101c0000
[ 5.765604] ehci-platform 101c0000.ehci: USB 2.0 started, EHCI 1.00
[ 5.773204] hub 1-0:1.0: USB hub found
[ 5.777662] hub 1-0:1.0: 1 port detected
[ 5.796239] shift_io@0 enforce active low on chipselect handle
[ 5.806545] gpio-export gpio-export: 5 gpio(s) exported
[ 5.820116] usbcore: registered new interface driver usb-storage
[ 5.833891] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[ 5.851824] init: - preinit -
[ 6.134265] usb 1-1: new high-speed USB device number 2 using ehci-platform
[ 6.534936] random: procd: uninitialized urandom read (4 bytes read)
[ 8.002462] random: jshn: uninitialized urandom read (4 bytes read)
[ 8.090403] random: jshn: uninitialized urandom read (4 bytes read)
[ 8.297266] mount_root: loading kmods from internal overlay
[ 8.424878] kmodloader: loading kernel modules from //etc/modules-boot.d/*
[ 8.437780] kmodloader: done loading kernel modules from //etc/modules-boot.d/*
[ 9.823006] jffs2: notice: (525) jffs2_build_xattr_subsystem: complete building xattr subsystem, 43 of xdatum (43 unchecked, 0 orphan) and 71 of xref (0 dead, 0 orphan) found.
[ 9.839785] block: attempting to load /tmp/jffs_cfg/upper/etc/config/fstab
[ 9.859341] block: extroot: not configured
[ 9.998777] jffs2: notice: (523) jffs2_build_xattr_subsystem: complete building xattr subsystem, 43 of xdatum (43 unchecked, 0 orphan) and 71 of xref (0 dead, 0 orphan) found.
[ 10.016662] mount_root: loading kmods from internal overlay
[ 10.173143] kmodloader: loading kernel modules from /tmp/overlay/upper/etc/modules-boot.d/*
[ 10.186275] kmodloader: done loading kernel modules from /tmp/overlay/upper/etc/modules-boot.d/*
[ 11.227987] block: attempting to load /tmp/jffs_cfg/upper/etc/config/fstab
[ 11.242865] block: extroot: not configured
[ 11.248640] mount_root: switching to jffs2 overlay
[ 11.260267] overlayfs: upper fs does not support tmpfile.
[ 11.275945] urandom-seed: Seeding with /etc/urandom.seed
[ 11.489562] random: mctl: uninitialized urandom read (4 bytes read)
[ 11.680927] procd: - early -
[ 11.684089] procd: - watchdog -
[ 12.032836] random: jshn: uninitialized urandom read (4 bytes read)
[ 12.307302] random: jshn: uninitialized urandom read (4 bytes read)
[ 12.348684] procd: - watchdog -
[ 12.359681] procd: - ubus -
[ 12.509886] random: ubusd: uninitialized urandom read (4 bytes read)
[ 12.527905] random: ubusd: uninitialized urandom read (4 bytes read)
[ 12.549914] random: ubusd: uninitialized urandom read (4 bytes read)
[ 12.578869] procd: - init -
[ 14.342689] random: jshn: uninitialized urandom read (4 bytes read)
[ 15.478245] jffs2: notice: (739) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
[ 15.558978] urngd: v1.0.2 started.
[ 15.951919] random: crng init done
[ 15.955438] random: 28 urandom warning(s) missed due to ratelimiting
[ 16.280589] kmodloader: loading kernel modules from /etc/modules.d/*
[ 16.485807] ntfs: driver 2.1.32 [Flags: R/O MODULE].
[ 16.512865] NET: Registered protocol family 15
[ 16.523612] Initializing XFRM netlink socket
[ 16.534565] tun: Universal TUN/TAP device driver, 1.6
[ 16.614564] l2tp_core: L2TP core driver, V2.0
[ 16.627908] l2tp_netlink: L2TP netlink interface
[ 16.644989] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 16.675329] l2tp_eth: L2TP ethernet pseudowire support (L2TPv3)
[ 16.694925] l2tp_ip: L2TP IP encapsulation support (L2TPv3)
[ 16.725353] l2tp_ip6: L2TP IP encapsulation support for IPv6 (L2TPv3)
[ 16.896539] gre: GRE over IPv4 demultiplexor driver
[ 16.905025] ip_gre: GRE over IPv4 tunneling driver
[ 16.928543] ip6_gre: GRE over IPv6 tunneling driver
[ 17.184586] usbcore: registered new interface driver usbserial_generic
[ 17.191399] usbserial: USB Serial support registered for generic
[ 17.219503] usbcore: registered new interface driver cypress_reconf
[ 17.226063] usbcore: registered new interface driver cypress_serial
[ 17.232578] usbserial: USB Serial support registered for CY7C65213-32LTXIT
[ 17.304984] i2c /dev entries driver
[ 17.330689] i2c-mt7621 10000900.i2c: clock 100 kHz
[ 17.363656] GACT probability on
[ 17.376454] Mirror/redirect action on
[ 17.445102] u32 classifier
[ 17.447954] input device check on
[ 17.451675] Actions configured
[ 17.509153] fuse: init (API version 7.31)
[ 17.595893] usbcore: registered new interface driver ark3116
[ 17.601853] usbserial: USB Serial support registered for ark3116
[ 17.652828] usbcore: registered new interface driver belkin_sa
[ 17.658956] usbserial: USB Serial support registered for Belkin / Peracom / GoHubs USB Serial Adapter
[ 17.706151] usbcore: registered new interface driver cdc_acm
[ 17.711950] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 17.736692] usbcore: registered new interface driver cdc_wdm
[ 17.755364] usbcore: registered new interface driver ch341
[ 17.761131] usbserial: USB Serial support registered for ch341-uart
[ 17.823252] Loading modules backported from Linux version v5.10.68-0-g4d8524048a35
[ 17.831015] Backport generated by backports.git v5.10.68-1-0-ga4f9ba32
[ 17.879689] usbcore: registered new interface driver cp210x
[ 17.885545] usbserial: USB Serial support registered for cp210x
[ 17.924485] usbcore: registered new interface driver cypress_m8
[ 17.930708] usbserial: USB Serial support registered for DeLorme Earthmate USB
[ 17.938191] usbserial: USB Serial support registered for HID->COM RS232 Adapter
[ 17.945757] usbserial: USB Serial support registered for Nokia CA-42 V2 Adapter
[ 18.088832] usbcore: registered new interface driver ftdi_sio
[ 18.094872] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 18.263131] usbcore: registered new interface driver pl2303
[ 18.268985] usbserial: USB Serial support registered for pl2303
[ 18.323159] usbcore: registered new interface driver usblp
[ 18.393764] xt_time: kernel timezone is -0000
[ 18.403468] usbcore: registered new interface driver cdc_ether
[ 18.417411] usbcore: registered new interface driver cdc_ncm
[ 18.802740] mt76_wmac 10300000.wmac: ASIC revision: 76280001
[ 19.887826] mt76_wmac 10300000.wmac: Firmware Version: 20151201
[ 19.893907] mt76_wmac 10300000.wmac: Build Time: 20151201183641
[ 19.917606] mt76_wmac 10300000.wmac: firmware init done
[ 20.085372] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 20.357306] usbcore: registered new interface driver option
[ 20.363186] usbserial: USB Serial support registered for GSM modem (1-port)
[ 20.370788] option 1-1:1.0: GSM modem (1-port) converter detected
[ 20.377380] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB0
[ 20.384784] option 1-1:1.1: GSM modem (1-port) converter detected
[ 20.391395] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB1
[ 20.398809] option 1-1:1.2: GSM modem (1-port) converter detected
[ 20.405431] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB2
[ 20.412830] option 1-1:1.3: GSM modem (1-port) converter detected
[ 20.419460] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB3
[ 20.529257] PPP generic driver version 2.4.2
[ 20.542819] PPP MPPE Compression module registered
[ 20.559866] NET: Registered protocol family 24
[ 20.576177] PPTP driver version 0.8.5
[ 20.597146] qmi_wwan: probe of 1-1:1.4 failed with error -22
[ 20.605125] qmi_wwan 1-1:1.5: cdc-wdm0: USB WDM device
[ 20.618929] qmi_wwan 1-1:1.5 wwan0: register 'qmi_wwan' at usb-101c0000.ehci-1, WWAN/QMI device, XX:XX:XX:XX:XX:XX
[ 20.629830] usbcore: registered new interface driver qmi_wwan
[ 20.677920] usbcore: registered new interface driver rndis_host
[ 20.698443] wireguard: WireGuard 1.0.0 loaded. See www.wireguard.com for information.
[ 20.706467] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld <Jason@zx2c4.com>. All Rights Reserved.
[ 20.801972] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 20.856489] kmodloader: done loading kernel modules from /etc/modules.d/*
[ 29.255183] rt3050-esw 10110000.esw: link changed 0x00
[ 46.125930] br-lan: port 1(eth0.1) entered blocking state
[ 46.131476] br-lan: port 1(eth0.1) entered disabled state
[ 46.137436] device eth0.1 entered promiscuous mode
[ 46.142366] device eth0 entered promiscuous mode
[ 46.180152] br-lan: port 1(eth0.1) entered blocking state
[ 46.185719] br-lan: port 1(eth0.1) entered forwarding state
[ 47.126314] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
[ 65.047493] br-lan: port 2(wlan0) entered blocking state
[ 65.052977] br-lan: port 2(wlan0) entered disabled state
[ 65.058860] device wlan0 entered promiscuous mode
[ 67.758665] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 67.765461] br-lan: port 2(wlan0) entered blocking state
[ 67.770920] br-lan: port 2(wlan0) entered forwarding state
[ 69.028134] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0-1: link becomes ready
[ 69.543125] qmi_wwan 1-1:1.5 wwan0: mode: raw IP
[ 72.584514] kmodloader: loading kernel modules from /etc/modules-late.d/*
[ 72.630573] kmodloader: done loading kernel modules from /etc/modules-late.d/*
[ 3568.416317] nf_conntrack: default automatic helper assignment has been turned off for security reasons and CT-based firewall rule not found. Use the iptables CT target to attach helpers instead.
[396502.542955] mt76_wmac 10300000.wmac: MCU message 08 (seq 9) timed out
[396505.614955] mt76_wmac 10300000.wmac: MCU message 08 (seq 10) timed out
[396508.686955] mt76_wmac 10300000.wmac: MCU message 08 (seq 11) timed out
[396511.759001] mt76_wmac 10300000.wmac: MCU message 08 (seq 12) timed out
[396514.830954] mt76_wmac 10300000.wmac: MCU message 08 (seq 13) timed out
[396517.902957] mt76_wmac 10300000.wmac: MCU message 08 (seq 14) timed out
[396520.975032] mt76_wmac 10300000.wmac: MCU message 08 (seq 15) timed out
[396524.046953] mt76_wmac 10300000.wmac: MCU message 08 (seq 1) timed out
[396527.118953] mt76_wmac 10300000.wmac: MCU message 08 (seq 2) timed out
[396530.190965] mt76_wmac 10300000.wmac: MCU message 08 (seq 3) timed out
[396533.262953] mt76_wmac 10300000.wmac: MCU message 08 (seq 4) timed out
[396536.334953] mt76_wmac 10300000.wmac: MCU message 08 (seq 5) timed out
[396539.407009] mt76_wmac 10300000.wmac: MCU message 08 (seq 6) timed out
[396542.479040] mt76_wmac 10300000.wmac: MCU message 08 (seq 7) timed out
[522310.924839] mt76_wmac 10300000.wmac: MCU message 08 (seq 8) timed out
[522315.020839] mt76_wmac 10300000.wmac: MCU message 08 (seq 9) timed out
[522318.092837] mt76_wmac 10300000.wmac: MCU message 08 (seq 10) timed out
[522321.164840] mt76_wmac 10300000.wmac: MCU message 08 (seq 11) timed out
[522324.236840] mt76_wmac 10300000.wmac: MCU message 08 (seq 12) timed out
[522327.308840] mt76_wmac 10300000.wmac: MCU message 08 (seq 13) timed out
[522330.380838] mt76_wmac 10300000.wmac: MCU message 08 (seq 14) timed out
[522333.452838] mt76_wmac 10300000.wmac: MCU message 08 (seq 15) timed out
[522336.524839] mt76_wmac 10300000.wmac: MCU message 08 (seq 1) timed out
[522339.596837] mt76_wmac 10300000.wmac: MCU message 08 (seq 2) timed out
[522342.668840] mt76_wmac 10300000.wmac: MCU message 08 (seq 3) timed out
[522345.740837] mt76_wmac 10300000.wmac: MCU message 08 (seq 4) timed out
[522348.812837] mt76_wmac 10300000.wmac: MCU message 08 (seq 5) timed out
[522351.884837] mt76_wmac 10300000.wmac: MCU message 08 (seq 6) timed out
[522533.900840] mt76_wmac 10300000.wmac: MCU message 08 (seq 7) timed out
[522537.996834] mt76_wmac 10300000.wmac: MCU message 08 (seq 8) timed out
[522541.068851] mt76_wmac 10300000.wmac: MCU message 08 (seq 9) timed out
[522544.140846] mt76_wmac 10300000.wmac: MCU message 08 (seq 10) timed out
[522547.212933] mt76_wmac 10300000.wmac: MCU message 08 (seq 11) timed out
[522550.284894] mt76_wmac 10300000.wmac: MCU message 08 (seq 12) timed out
[522553.356970] mt76_wmac 10300000.wmac: MCU message 08 (seq 13) timed out
[522556.428852] mt76_wmac 10300000.wmac: MCU message 08 (seq 14) timed out
[522559.500834] mt76_wmac 10300000.wmac: MCU message 08 (seq 15) timed out
[522562.572834] mt76_wmac 10300000.wmac: MCU message 08 (seq 1) timed out
[522565.644834] mt76_wmac 10300000.wmac: MCU message 08 (seq 2) timed out
[522568.716832] mt76_wmac 10300000.wmac: MCU message 08 (seq 3) timed out
[522571.788834] mt76_wmac 10300000.wmac: MCU message 08 (seq 4) timed out
[522574.860833] mt76_wmac 10300000.wmac: MCU message 08 (seq 5) timed out
