I have a problem accessing via wifi to my RUT951 (FW version RUT9M_R_00.07.04.3), the access point is visible (SSID RUT951_4951) but when I try to connect I get no reply! If I digit purposely a wrong password then the router replies the messagge “wrong password”. So it seems that for some reason the access is denied…
The router is currently reacheable via ethernet cable and I successfully use it for connecting to a remote board (port forwarding) and a personal computer.
The wifi configuration is thr default one, I didn’t modify any parameter so what’s wrong with it?
Thank you for your help
Regards, Sandro
