I’m using a RUT951 and Sim Card with Public Static IP address, I have set up the port forward to access web based program on the PC that the RUT951 is connected to via LAN, I can access the web page with the Public Static IP address of the Sim Card, so that part is working.
However I have now introduced few clients (satellite sites) to connect to the Master RUT951 (the one with public static IP) via OpenVpn, however my client sites are unable to connect to the server if the Port Forwarding is on and as soon as I disable the Port Forwarding the Clients will connect and stay connected.
However my problem arises when the Clients disconnect from the OpenVpn they have no way of automatically reconnecting to the VPN as long as the Port Forwarding is on.
Is there any way to overcome this? is this a bug or set up issue? anyone else experience this?
Thanks in advance for all your input!
