I have a question about connecting a RUT951 router to switch using the following configuration (camera-PoE switch -RUT951). My question is, can I connect a 16 Ports PoE with 16 cameras? or the limit is 4 port as it’s been described in manual? * Camera access from smartphone.
Hi…
Please, look at the datasheet.
About RUT951
The Teltonika RUT951, a 4G LTE Cat 4 router, offers mobile throughput speeds of up to 150 Mbps downlink and 50 Mbps uplink.
Here’s a more detailed breakdown:
- 4G LTE Cat 4: The RUT951 utilizes 4G LTE Cat 4 technology.
- Throughput: It’s capable of achieving mobile throughput speeds of up to 150 Mbps downlink and 50 Mbps uplink.
- Other Features:
- Dual-SIM with auto-failover
- Wireless access point with hotspot functionality
- 4 Ethernet interfaces with VLAN support
- Automatic WAN failover
- Robust aluminum housing
- Remote Management System
- Mobile Module: 4G (LTE) - Cat 4 up to 150 Mbps, 3G - Up to 42 Mbps, 2G - Up to 236.8 kbps.
- Wireless: IEEE 802.11b/g/n, Access Point (AP), Station (STA).
- Ethernet: 1 x WAN port 10/100 Mbps, 3 x LAN ports 10/100 Mbps.
(Google)
So… You can connect an external switch at the device, but need to check about the throughput needed to keep 16 cameras working.
Hello @milond2003,
Could you please confirm whether your issue has been resolved, or if you still require assistance?
