RUT951
RUT9M_R_00.07.19.4**
I have an issue with my Teltonika RUT951 router. The router randomly drops the Wi-Fi connection.
When it happens:
all devices disconnect from Wi-Fi,
the Wi-Fi network/SSID disappears and is not available,
it happens randomly, with no clear pattern.
Additional details:
I have a daily reboot scheduled at 06:00,
I run a continuous ping to the router IP:
ping 192.168.2.1 -t, so I can see when I lose access, -
sometimes I also see latency spikes to the router, for example:
Reply from 192.168.2.1: bytes=32 time=6ms TTL=64
Reply from 192.168.2.1: bytes=32 time=1ms TTL=64
Reply from 192.168.2.1: bytes=32 time=181ms TTL=64
Reply from 192.168.2.1: bytes=32 time=3ms TTL=64
Reply from 192.168.2.1: bytes=32 time=4ms TTL=64
Reply from 192.168.2.1: bytes=32 time=36ms TTL=64
Reply from 192.168.2.1: bytes=32 time=10ms TTL=64
Reply from 192.168.2.1: bytes=32 time=43ms TTL=64
Reply from 192.168.2.1: bytes=32 time=2ms TTL=64
Reply from 192.168.2.1: bytes=32 time=31ms TTL=64
ase help me diagnose this issue. Let me know what logs or details I should provide.
