Could I get help for adding LLDP and if possible DCP for Siemens automation?
Found some old guides, but as far as I can tell LLDP packed is not available anymore?
Please check the instructions provided at the following link: Siemens PLC - Visible devices over AP - Crowd Support Forum | Teltonika Networks.
This is guide I referred as not working - package seems to be removed:
root@RUT951:~# opkg update
Downloading https://opkg.teltonika-networks.com/1e7c44aac6c6b9ce079df8bec59aea9d992de50a7609e9fe68d86d15accf42f4/Packages.gz
Updated list of available packages in /var/opkg-lists/tlt_packages
Downloading https://opkg.teltonika-networks.com/1e7c44aac6c6b9ce079df8bec59aea9d992de50a7609e9fe68d86d15accf42f4/Packages.sig
Signature check passed.
root@RUT951:~# opkg list | grep -i lldp
root@RUT951:~# opkg install lldpd
Unknown package ‘lldpd’.
Package installation encountered an error, removing previously installed packages.
Do instead:
opkg -e /etc/opkg/openwrt/distfeeds.conf install lldpd
