RUT951 Connection stage Initializing modem
RUT951 worked at least until Fall 2023. Now it does not work.
Firmware RUT9M_R_00.07.10.
Operator state Not registered
SIM card slot in use SIM 1
SIM card state Inserted
Provider N/A
Could you please provide more details? Could you confirm if you meant that the device has been unused for a year, or did you mean it stopped connecting to the mobile network since last year? Do you recall how it stopped working—perhaps after specific configurations?
Have you tested this SIM card in another device, such as a phone? Did it connect to the network successfully? Additionally, if you haven’t already, please try using a different SIM card in your RUT951.
If the device isn’t working correctly, you can also try resetting it to factory settings or using the bootloader menu if a reset doesn’t help. More information on recovery options is available on our wiki page here: RUT951 Device Recovery Options.
It stopped working after changing OPTUS SIM AU (worked a couple years) to TELE2 SIM RU. I tried everything that you mentioned.
Do you mean it is not connecting to russian operator?
I guess so.
The device is functioning as intended. It has been specifically designed to restrict connections to russian and belarusian operators
When that restriction was applied to firmware? I would like to install the latest software that will work.
