RUT951 connection problem
I have a problem with my RUT951 and I need to solve it quickly because it’s urgent.
It worked with my colleague, but not with me.
It flashes red and green all the time.
Can you please help me solve this problem?
Thank you for reaching out.
Could you please check if the SIM card is inserted correctly and, if it requires a PIN, ensure the PIN is entered in Network → Mobile on the WebUI?
Thank you for your feedback.
Everything is in order. Chip installed correctly and PIN code correct.
I have to admit that I logged on to the WebUI by creating another account. Could this be the cause of the problem?
Thank you
Any help please ?
Connection state in FAILURE
Could you please connect to the router’s CLI (System → Maintenance → CLI or via SSH) and execute the following command: /etc/init.d/rms_mqtt restart.
Alternatively, this can be done in the WebUI by setting Connection type to Disabled, clicking Save & Apply, then waiting a few moments before setting it back to Enabled and saving again.
If this doesn’t resolve the issue, try performing a factory reset and re-registering the device to RMS.
I tried to type the command on the CLI interface, but it asked me for the username and password instead.
It won’t let me enter the password.
It’s not easy, I’m stuck. :slightly_smiling_face:
Could you please show me some screenshots ?
Thank you very much
Hi @Abdelhak,
username is admin
password is the sam as in the WebGUI
password is NOT shown while typing (no *** no … nothing!)
Timelapse Admin
The login username is root, and the password is your current device admin password:
As Timelapse Admin mentioned, the password will not be visible as you type it.
Normally, I’ve managed to do what’s necessary but the RUT951 is still flashing green and red. I haven’t noticed any change.
continued
Could you please navigate to Network → WAN, click Edit on the mob1s1a1 interface, and set the PDP type to IPv4 only? After making this change, restart the RMS service once again.
Martynas,
why can’t I find the tab you’re showing me ?
Look :
Thank you a lot
Sorry, I was in ADVANCED mode.
I found it like this
Please,
To restart the RMS service, I press REBOOT ?
Thank you
Your device is unable to connect to RMS because it is not currently connected to the internet. Additionally, it appears you are using an older firmware version. We always recommend updating to the latest version for the RUT951, which can be downloaded here.
Once you have downloaded the firmware image file, you can upload it via the System → Firmware page by selecting the Update from File option.
To resolve the RMS connection issue, please ensure that your router is connected to the internet using a wired WAN, mobile (SIM card), or wireless connection.
I’m very grateful for your precise help.
I was finally able to fix the problem following your instructions.
Bonne continuation, :wink: :wave:
Thank you for the update – I’m very glad to hear the issue was resolved! If you need any further assistance, please don’t hesitate to reach out.
