starting from version 7 I can’t change APN via SMS command as used in past with V6.xx
The SMS sent is “Router Password cellular apn=wap.tim.it” without quotes".
The answer I get from Router log is
Where is the error?
Matteo
Where is the error?
Matteo
Could you please try the following SMS (assuming you use SIM slot 1):
#replace <admin01> with your password and <yourapn> with your actual APN
admin01 uci set network.mob1s1a1.apn=yourapn
If the SIM card is in slot 2, use mob1s2a1 instead.
Let me know if it works then.
