Hello, how can I bridge LAN and ZeroTier VPN on old RUT950(legacy firmware 6) ?
If you’re referring to creating a Layer 2 (L2) bridge between the LAN and a ZeroTier VPN on a RUT950 with legacy firmware, unfortunately, this isn’t possible, as only L3 VPN connectivity is supported on that firmware version. More information can be found in the related wiki article here:
ZeroTier One VPN configuration (Legacy Firmware)
However, a potential, though slightly riskier, workaround would be to first update your RUT950 to the latest legacy firmware version (6.09.5) and then attempt an upgrade to a RutOS 7.X.X release, where ZeroTier L2 bridging is supported. You can follow the detailed configuration steps available on the wiki ZeroTier (RutOS) configuration example here:
ZeroTier Configuration (RutOS)
Also, one important note to mention: FW version RUT9_R_00.07.00 and above is not supported on legacy-design (RUT950 XG1XXX) devices.
