Rut950 Wan as WiFi Client Problem
Ok been using the RUT950 in my Motorhome with a SIM card inserted as metric 2 on failover and my home Wifi network as metric 1. When I’m at home the Rut950 connects to my home Wifi and when I’m away it uses the sim connection. All works well. As I have unlimited data on my mobile I wanted to add my mobile as metric 2 and put the sim as metric 3 on the failover setup. As the RUT950 can only connect as a client to one Wifi signal I have added a MikroTik maP lite which is configured as a client to the Wan port on the RUT950. All works well for a few hours and then I loose internet access on all 3 connections. Just wondering if there’s a setting somewhere that needs changing as it seems to be the same length of time for the drop out to occur. I’ve rebooted the RUT950 to my non Wan enabled setup and it’s working fine again. Any help getting the Wan working would be appreciated.
Done a bit more playing around and with WAN set as no1 in failover, mobile phone hotspot set as no 2 and sim modem set at 3, I’m still having problems. Failover works fine for a few hours but even with nothing connected to the WAN port I loose internet connectivity after a period of time even though the unit has failed over to the Sim Modem and worked initially. If I disable the WAN port the internet connection returns and will stay connected indefinitely.
I’m stuck for a solution because I thought these units were designed to be a back up for a WAN wired connection.
What firmware version is installed on your RUT950?
Could you please share your failover and WAN configurations? If you have any public IP addressess, please hide those before sharing your configurations here.
Also, please wait for the issue to replicate, then navigate to System → Maintenance → Troubleshoot, open System Logs, and paste the logs that were generated around the time when the issue occured.
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 15.581292] l2tp_eth: L2TP ethernet pseudowire support (L2TPv3)
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 15.600999] l2tp_ip: L2TP IP encapsulation support (L2TPv3)
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 15.629140] l2tp_ip6: L2TP IP encapsulation support for IPv6 (L2TPv3)
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 15.639969] gre: GRE over IPv4 demultiplexor driver
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 15.672450] ip_gre: GRE over IPv4 tunneling driver
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 15.717865] ip6_gre: GRE over IPv6 tunneling driver
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 16.089592] tlt-gpio: set names for 18040000.gpio chip
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 16.096156] tlt-gpio: set names for 74hc595 chip
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 16.121486] GACT probability on
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 16.140347] Mirror/redirect action on
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 16.188677] u32 classifier
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 16.191497] input device check on
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 16.195239] Actions configured
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 16.253508] fuse: init (API version 7.31)
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 16.281459] usbcore: registered new interface driver usbserial_generic
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 16.288277] usbserial: USB Serial support registered for generic
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 16.316823] usbcore: registered new interface driver cypress_reconf
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 16.323368] usbcore: registered new interface driver cypress_serial
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 16.329889] usbserial: USB Serial support registered for CY7C65213
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 16.482850] usbcore: registered new interface driver ark3116
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 16.488765] usbserial: USB Serial support registered for ark3116
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 16.548117] usbcore: registered new interface driver belkin_sa
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 16.554251] usbserial: USB Serial support registered for Belkin / Peracom / GoHubs USB Serial Adapter
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 16.598591] usbcore: registered new interface driver cdc_acm
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 16.604396] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 16.630756] usbcore: registered new interface driver cdc_wdm
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 16.644084] usbcore: registered new interface driver ch341
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 16.649850] usbserial: USB Serial support registered for ch341-uart
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 16.686533] usbcore: registered new interface driver usb_ch343
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 16.692511] ch343: USB serial driver for ch342/ch343/ch344/ch347/ch9101/ch9102/ch9103/ch9104, etc.
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 16.701616] ch343: V1.5 On 2022.12
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 16.740288] Loading modules backported from Linux version v5.10.68-0-g4d8524048a35
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 16.748044] Backport generated by backports.git v5.10.68-1-0-ga4f9ba32
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 16.772025] usbcore: registered new interface driver cp210x
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 16.777887] usbserial: USB Serial support registered for cp210x
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 16.808753] usbcore: registered new interface driver cypress_m8
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 16.814973] usbserial: USB Serial support registered for DeLorme Earthmate USB
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 16.822456] usbserial: USB Serial support registered for HID->COM RS232 Adapter
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 16.830013] usbserial: USB Serial support registered for Nokia CA-42 V2 Adapter
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 17.038546] usbcore: registered new interface driver ftdi_sio
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 17.044565] usbserial: USB Serial support registered for FTDI USB Serial Device
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 17.148872] mcp3021 0-004d: Scanning address range.
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 17.308627] usbcore: registered new interface driver pl2303
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 17.314480] usbserial: USB Serial support registered for pl2303
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 17.390607] usbcore: registered new interface driver usblp
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 17.623587] xt_time: kernel timezone is -0000
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 18.529785] usbcore: registered new interface driver option
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 18.535638] usbserial: USB Serial support registered for GSM modem (1-port)
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 18.543268] option 1-1:1.0: GSM modem (1-port) converter detected
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 18.549890] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB0
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 18.557296] option 1-1:1.1: GSM modem (1-port) converter detected
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 18.563923] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB1
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 18.571346] option 1-1:1.2: GSM modem (1-port) converter detected
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 18.577960] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB2
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 18.585356] option 1-1:1.3: GSM modem (1-port) converter detected
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 18.591984] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB3
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 18.806130] PPP generic driver version 2.4.2
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 18.819567] PPP MPPE Compression module registered
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 18.832689] NET: Registered protocol family 24
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 18.848283] PPTP driver version 0.8.5
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 18.876932] qmi_wwan 1-1:1.4: cdc-wdm0: USB WDM device
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 18.891437] qmi_wwan 1-1:1.4 wwan0: register ‘qmi_wwan’ at usb-1b000000.usb-1, WWAN/QMI device, a2:0a:7e:40:c0:96
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 18.902212] usbcore: registered new interface driver qmi_wwan
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 18.942815] wireguard: WireGuard 1.0.0 loaded. See www.wireguard.com for information.
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 18.950827] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld Jason@zx2c4.com. All Rights Reserved.
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 19.227469] l2tp_ppp: PPPoL2TP kernel driver, V2.0
Sun Mar 17 19:53:28 2024 user.warn kernel: [ 19.233560] [01-serial-symlink.sh] New device ttyUSB0 at /devices/platform/ahb/1b000000.usb/usb1/1-1/1-1:1.0/ttyUSB0/tty/ttyUSB0 appeared!
Sun Mar 17 19:53:28 2024 kern.debug kernel: [ 19.318690] ath: EEPROM regdomain sanitized
Sun Mar 17 19:53:28 2024 kern.debug kernel: [ 19.318704] ath: EEPROM regdomain: 0x64
Sun Mar 17 19:53:28 2024 kern.debug kernel: [ 19.318709] ath: EEPROM indicates we should expect a direct regpair map
Sun Mar 17 19:53:28 2024 kern.debug kernel: [ 19.318736] ath: Country alpha2 being used: 00
Sun Mar 17 19:53:28 2024 kern.debug kernel: [ 19.318741] ath: Regpair used: 0x64
Sun Mar 17 19:53:28 2024 kern.debug kernel: [ 19.332657] ieee80211 phy0: Selected rate control algorithm ‘minstrel_ht’
Sun Mar 17 19:53:28 2024 kern.info kernel: [ 19.335490] ieee80211 phy0: Atheros AR9340 Rev:3 mem=0xb8100000, irq=13
Sun Mar 17 19:53:28 2024 user.info kernel: [ 19.375049] kmodloader: done loading kernel modules from /etc/modules.d/*
Sun Mar 17 19:53:28 2024 user.warn kernel: [ 19.996418] [01-serial-symlink.sh] New device ttyUSB1 at /devices/platform/ahb/1b000000.usb/usb1/1-1/1-1:1.1/ttyUSB1/tty/ttyUSB1 appeared!
Sun Mar 17 19:53:28 2024 user.warn kernel: [ 20.770651] [01-serial-symlink.sh] New device ttyUSB2 at /devices/platform/ahb/1b000000.usb/usb1/1-1/1-1:1.2/ttyUSB2/tty/ttyUSB2 appeared!
Sun Mar 17 19:53:28 2024 user.warn kernel: [ 21.530320] [01-serial-symlink.sh] New device ttyUSB3 at /devices/platform/ahb/1b000000.usb/usb1/1-1/1-1:1.3/ttyUSB3/tty/ttyUSB3 appeared!
Sun Mar 17 19:53:32 2024 user.notice : Added device handler type: bonding
Sun Mar 17 19:53:32 2024 user.notice : Added device handler type: 8021ad
Sun Mar 17 19:53:32 2024 user.notice : Added device handler type: 8021q
Sun Mar 17 19:53:32 2024 user.notice : Added device handler type: macvlan
Sun Mar 17 19:53:32 2024 user.notice : Added device handler type: veth
Sun Mar 17 19:53:32 2024 user.notice : Added device handler type: bridge
Sun Mar 17 19:53:32 2024 user.notice : Added device handler type: Network device
Sun Mar 17 19:53:32 2024 user.notice : Added device handler type: tunnel
Sun Mar 17 19:53:34 2024 user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Sun Mar 17 19:53:34 2024 user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Sun Mar 17 19:53:36 2024 daemon.info dnsmasq[2057]: Connected to system UBus
Sun Mar 17 19:53:36 2024 daemon.info dnsmasq[2057]: started, version 2.85 cachesize 150
Sun Mar 17 19:53:36 2024 daemon.info dnsmasq[2057]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-regex no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-cryptohash no-DNSSEC no-ID loop-detect inotify dumpfile
Sun Mar 17 19:53:36 2024 daemon.info dnsmasq[2057]: UBus support enabled: connected to system bus
Sun Mar 17 19:53:36 2024 daemon.info dnsmasq[2057]: using only locally-known addresses for domain test
Sun Mar 17 19:53:36 2024 daemon.info dnsmasq[2057]: using only locally-known addresses for domain onion
Sun Mar 17 19:53:36 2024 daemon.info dnsmasq[2057]: using only locally-known addresses for domain localhost
Sun Mar 17 19:53:36 2024 daemon.info dnsmasq[2057]: using only locally-known addresses for domain invalid
Sun Mar 17 19:53:36 2024 daemon.info dnsmasq[2057]: using only locally-known addresses for domain bind
Sun Mar 17 19:53:36 2024 daemon.info dnsmasq[2057]: using only locally-known addresses for domain lan
Sun Mar 17 19:53:36 2024 daemon.warn dnsmasq[2057]: no servers found in /tmp/resolv.conf.d/resolv.conf.auto, will retry
Sun Mar 17 19:53:36 2024 daemon.info dnsmasq[2057]: read /etc/hosts - 4 addresses
Sun Mar 17 19:53:36 2024 daemon.info dnsmasq[2057]: read /tmp/hosts/dhcp.cfg01411c - 0 addresses
Sun Mar 17 19:53:41 2024 daemon.notice wpa_supplicant[2112]: Successfully initialized wpa_supplicant
Sun Mar 17 19:53:42 2024 daemon.info gsmd[2234]: gsmd-ng init
Sun Mar 17 19:53:42 2024 daemon.info gsmd[2234]: gsmd-ng canary build git#9cf5346253
Sun Mar 17 19:53:42 2024 daemon.info gsmd[2234]: AT traffic support: yes
Sun Mar 17 19:53:42 2024 daemon.info gsmd[2234]: Baseband feature support: no
Sun Mar 17 19:53:42 2024 daemon.info gsmd[2234]: gsmd-ng running
Sun Mar 17 19:53:45 2024 daemon.notice procd: /etc/rc.d/S13openssl: Generating engines.cnf
Sun Mar 17 19:53:45 2024 daemon.notice procd: /etc/rc.d/S13openssl: Generating providers.cnf
Sun Mar 17 19:53:45 2024 daemon.notice procd: /etc/rc.d/S13openssl: Enabling legacy
Sun Mar 17 19:53:46 2024 daemon.info mobifd: [gsm.modem0] Starting modem settings init
Sun Mar 17 19:53:46 2024 daemon.info mobifd: [gsm.modem0] SIM is ready
Sun Mar 17 19:53:46 2024 daemon.err mobifd: [gsm.modem0] GSM error in “generic_enable_urc_cause:638” (Failed to parse response), gsmd_method_id: “163”
Sun Mar 17 19:53:48 2024 daemon.info mobifd: [gsm.modem0] Modem settings init completed
Sun Mar 17 19:53:48 2024 daemon.info mobifd: [gsm.modem0] Starting connection setup
Sun Mar 17 19:53:49 2024 daemon.info mobifd: [gsm.modem0] Attempting to establish connection to operator with “15s” of timeout
Sun Mar 17 19:53:49 2024 daemon.info mobifd: [gsm.modem0] Connected to operator “O2 - UK giffgaff”
Sun Mar 17 19:53:49 2024 daemon.info mobifd: [gsm.modem0] -CFUN- Functionality: “Full”
Sun Mar 17 19:53:49 2024 daemon.info mobifd: [gsm.modem0] -COPS- Mode: “Auto”, operator: “O2 - UK giffgaff”
Sun Mar 17 19:53:49 2024 daemon.info mobifd: [gsm.modem0] -CREG- Mode: “Enabled (with location information)”, status: “Registered, home”, LAC: “1249”, cell ID: “130088583”, technology: “E-UTRAN”
Sun Mar 17 19:53:49 2024 daemon.info mobifd: [gsm.modem0] -CGREG- Mode: “Enabled (with location information)”, status: “Registered, home”, LAC: “1249”, cell ID: “130088583”, technology: “E-UTRAN”
Sun Mar 17 19:53:49 2024 daemon.info mobifd: [gsm.modem0] -CEREG- Mode: “Enabled (with location information)”, status: “Registered, home”, LAC: “1249”, cell ID: “130088583”, technology: “E-UTRAN”
Sun Mar 17 19:53:49 2024 daemon.info mobifd: [gsm.modem0] IP address on PDP context “1”: “10.150.169.99”
Sun Mar 17 19:53:57 2024 authpriv.info dropbear[2667]: Not backgrounding
Sun Mar 17 19:54:01 2024 kern.info kernel: [ 59.606520] eth0: link up (1000Mbps/Full duplex)
Sun Mar 17 19:54:01 2024 kern.info kernel: [ 59.629112] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Sun Mar 17 19:54:01 2024 kern.info kernel: [ 59.639724] br-lan: port 1(eth0.1) entered blocking state
Sun Mar 17 19:54:01 2024 kern.info kernel: [ 59.645288] br-lan: port 1(eth0.1) entered disabled state
Sun Mar 17 19:54:01 2024 kern.info kernel: [ 59.651369] device eth0.1 entered promiscuous mode
Sun Mar 17 19:54:01 2024 kern.info kernel: [ 59.656297] device eth0 entered promiscuous mode
Sun Mar 17 19:54:01 2024 kern.info kernel: [ 59.708733] br-lan: port 1(eth0.1) entered blocking state
Sun Mar 17 19:54:01 2024 kern.info kernel: [ 59.714294] br-lan: port 1(eth0.1) entered forwarding state
Sun Mar 17 19:54:02 2024 daemon.notice netifd: Interface ‘lan’ is enabled
Sun Mar 17 19:54:02 2024 daemon.notice netifd: Interface ‘lan’ is setting up now
Sun Mar 17 19:54:02 2024 daemon.notice netifd: Interface ‘lan’ is now up
Sun Mar 17 19:54:02 2024 daemon.notice netifd: bridge ‘br-lan’ link is up
Sun Mar 17 19:54:02 2024 daemon.notice netifd: Interface ‘lan’ has link connectivity
Sun Mar 17 19:54:02 2024 daemon.notice netifd: Interface ‘loopback’ is enabled
Sun Mar 17 19:54:02 2024 daemon.notice netifd: Interface ‘loopback’ is setting up now
Sun Mar 17 19:54:02 2024 daemon.notice netifd: Interface ‘loopback’ is now up
Sun Mar 17 19:54:02 2024 daemon.notice netifd: Interface ‘wan’ is enabled
Sun Mar 17 19:54:02 2024 daemon.notice netifd: Interface ‘wan’ is setting up now
Sun Mar 17 19:54:02 2024 daemon.notice netifd: Interface ‘wan6’ is enabled
Sun Mar 17 19:54:02 2024 daemon.notice netifd: VLAN ‘eth0.1’ link is up
Sun Mar 17 19:54:02 2024 daemon.notice netifd: Interface ‘mob1s1a1’ is setting up now
Sun Mar 17 19:54:02 2024 daemon.notice netifd: bridge ‘br-lan’ link is down
Sun Mar 17 19:54:02 2024 daemon.notice netifd: Interface ‘lan’ has link connectivity loss
Sun Mar 17 19:54:02 2024 daemon.notice netifd: VLAN ‘eth0.1’ link is down
Sun Mar 17 19:54:02 2024 daemon.notice netifd: Network device ‘eth0’ link is up
Sun Mar 17 19:54:02 2024 daemon.notice netifd: Network device ‘lo’ link is up
Sun Mar 17 19:54:02 2024 daemon.notice netifd: Interface ‘loopback’ has link connectivity
Sun Mar 17 19:54:02 2024 kern.info kernel: [ 60.622733] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
Sun Mar 17 19:54:03 2024 daemon.notice netifd: wan (2874): udhcpc: started, v1.34.1
Sun Mar 17 19:54:04 2024 kern.info kernel: [ 61.864201] eth1: link up (100Mbps/Full duplex)
Sun Mar 17 19:54:04 2024 daemon.notice netifd: Network device ‘eth1’ link is up
Sun Mar 17 19:54:04 2024 daemon.notice netifd: Interface ‘wan’ has link connectivity
Sun Mar 17 19:54:04 2024 daemon.notice netifd: Interface ‘wan6’ has link connectivity
Sun Mar 17 19:54:04 2024 daemon.notice netifd: Interface ‘wan6’ is setting up now
Sun Mar 17 19:54:04 2024 kern.info kernel: [ 61.902018] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
Sun Mar 17 19:54:04 2024 daemon.notice netifd: wan (2874): udhcpc: broadcasting discover
Sun Mar 17 19:54:05 2024 daemon.notice netifd: radio0 (2835): WARNING: Variable ‘data’ does not exist or is not an array/object
Sun Mar 17 19:54:05 2024 daemon.notice netifd: mob1s1a1 (2846): wwan[2846] Using wwan usb device on bus 1-1
Sun Mar 17 19:54:06 2024 daemon.notice odhcp6c[2959]: (re)starting transaction on eth1
Sun Mar 17 19:54:06 2024 daemon.info odhcp6c[2959]: Interface eth1 sending router solicitation message
Sun Mar 17 19:54:06 2024 daemon.notice netifd: mob1s1a1 (2846): wwan[2846] Using proto:qmux device:/dev/cdc-wdm0 iface:wwan0 desc:Quectel EC25
Sun Mar 17 19:54:06 2024 daemon.notice odhcp6c[2959]: Starting SOLICIT transaction (timeout 4294967295s, max rc 0)
Sun Mar 17 19:54:07 2024 daemon.notice netifd: wan (2874): udhcpc: broadcasting discover
Sun Mar 17 19:54:09 2024 kern.debug kernel: [ 67.610294] ath: EEPROM regdomain: 0x8348
Sun Mar 17 19:54:09 2024 kern.debug kernel: [ 67.610304] ath: EEPROM indicates we should expect a country code
Sun Mar 17 19:54:09 2024 kern.debug kernel: [ 67.610314] ath: doing EEPROM country->regdmn map search
Sun Mar 17 19:54:09 2024 kern.debug kernel: [ 67.610323] ath: country maps to regdmn code: 0x3a
Sun Mar 17 19:54:09 2024 kern.debug kernel: [ 67.610331] ath: Country alpha2 being used: US
Sun Mar 17 19:54:09 2024 kern.debug kernel: [ 67.610335] ath: Regpair used: 0x3a
Sun Mar 17 19:54:09 2024 kern.debug kernel: [ 67.610344] ath: regdomain 0x8348 dynamically updated by user
Sun Mar 17 19:54:10 2024 daemon.notice netifd: mob1s1a1 (2846): Quering active sim position
Sun Mar 17 19:54:10 2024 daemon.notice netifd: mob1s1a1 (2846): Calculated qmimux ifname: qmimux0
Sun Mar 17 19:54:10 2024 daemon.notice netifd: wan (2874): udhcpc: broadcasting discover
Sun Mar 17 19:54:11 2024 daemon.notice hostapd: Set new config for phy phy0:
Sun Mar 17 19:54:11 2024 daemon.notice wpa_supplicant[2112]: Set new config for phy phy0
Sun Mar 17 19:54:11 2024 daemon.notice netifd: wan (2874): udhcpc: broadcasting select for 192.168.88.254, server 192.168.88.1
Sun Mar 17 19:54:11 2024 daemon.notice netifd: wan (2874): udhcpc: lease of 192.168.88.254 obtained from 192.168.88.1, lease time 600
Sun Mar 17 19:54:12 2024 user.notice root: uqmi -d /dev/cdc-wdm0 --timeout 6000 --wda-set-data-format --link-layer-protocol raw-ip --ul-protocol qmap --dl-protocol qmap --dl-max-datagrams 16 --dl-datagram-max-size 4096 --ul-max-datagrams 11 --ul-datagram-max-size 4096 --dl-min-padding 0
Sun Mar 17 19:54:12 2024 daemon.notice netifd: Interface ‘wan’ is now up
Sun Mar 17 19:54:12 2024 daemon.info dnsmasq[2057]: reading /tmp/resolv.conf.d/resolv.conf.auto
Sun Mar 17 19:54:12 2024 daemon.info dnsmasq[2057]: using only locally-known addresses for domain test
Sun Mar 17 19:54:12 2024 daemon.info dnsmasq[2057]: using only locally-known addresses for domain onion
Sun Mar 17 19:54:12 2024 daemon.info dnsmasq[2057]: using only locally-known addresses for domain localhost
Sun Mar 17 19:54:12 2024 daemon.info dnsmasq[2057]: using only locally-known addresses for domain invalid
Sun Mar 17 19:54:12 2024 daemon.info dnsmasq[2057]: using only locally-known addresses for domain bind
Sun Mar 17 19:54:12 2024 daemon.info dnsmasq[2057]: using only locally-known addresses for domain lan
Sun Mar 17 19:54:12 2024 daemon.info dnsmasq[2057]: using nameserver 192.168.88.1#53
Sun Mar 17 19:54:13 2024 daemon.notice netifd: mob1s1a1 (2846): Starting network mob1s1a1 using APN: mobile.o2.co.uk
Sun Mar 17 19:54:14 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --set-client-id wds,17 --release-client-id wds --modify-profile --profile-identifier 3gpp,1 --profile-name profile1 --roaming-disallowed-flag no --auth-type none --apn mobile.o2.co.uk --pdp-type ipv4v6
Sun Mar 17 19:54:16 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --get-client-id wds
Sun Mar 17 19:54:16 2024 daemon.info dnsmasq[2057]: exiting on receipt of SIGTERM
Sun Mar 17 19:54:16 2024 daemon.info dnsmasq[3495]: Connected to system UBus
Sun Mar 17 19:54:16 2024 daemon.info dnsmasq[3495]: started, version 2.85 cachesize 150
Sun Mar 17 19:54:16 2024 daemon.info dnsmasq[3495]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-regex no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-cryptohash no-DNSSEC no-ID loop-detect inotify dumpfile
Sun Mar 17 19:54:16 2024 daemon.info dnsmasq[3495]: UBus support enabled: connected to system bus
Sun Mar 17 19:54:16 2024 daemon.info dnsmasq-dhcp[3495]: DHCP, IP range 192.168.1.100 – 192.168.1.249, lease time 12h
Sun Mar 17 19:54:16 2024 daemon.info dnsmasq[3495]: using only locally-known addresses for domain test
Sun Mar 17 19:54:16 2024 daemon.info dnsmasq[3495]: using only locally-known addresses for domain onion
Sun Mar 17 19:54:16 2024 daemon.info dnsmasq[3495]: using only locally-known addresses for domain localhost
Sun Mar 17 19:54:16 2024 daemon.info dnsmasq[3495]: using only locally-known addresses for domain invalid
Sun Mar 17 19:54:16 2024 daemon.info dnsmasq[3495]: using only locally-known addresses for domain bind
Sun Mar 17 19:54:16 2024 daemon.info dnsmasq[3495]: using only locally-known addresses for domain lan
Sun Mar 17 19:54:16 2024 daemon.info dnsmasq[3495]: reading /tmp/resolv.conf.d/resolv.conf.auto
Sun Mar 17 19:54:16 2024 daemon.info dnsmasq[3495]: using nameserver 192.168.88.1#53
Sun Mar 17 19:54:16 2024 daemon.info dnsmasq[3495]: read /etc/hosts - 4 addresses
Sun Mar 17 19:54:16 2024 daemon.info dnsmasq[3495]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Sun Mar 17 19:54:16 2024 daemon.info dnsmasq-dhcp[3495]: read /etc/ethers - 0 addresses
Sun Mar 17 19:54:17 2024 daemon.info dnsmasq[3495]: read /etc/hosts - 4 addresses
Sun Mar 17 19:54:17 2024 daemon.info dnsmasq[3495]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Sun Mar 17 19:54:17 2024 daemon.info dnsmasq-dhcp[3495]: read /etc/ethers - 0 addresses
Sun Mar 17 19:54:17 2024 daemon.notice netifd: mob1s1a1 (2846): 17
Sun Mar 17 19:54:17 2024 daemon.notice netifd: mob1s1a1 (2846): cid4: 17
Sun Mar 17 19:54:17 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --wds-bind-mux-data-port --mux-id 1 --ep-iface-number 4 --set-client-id wds,17
Sun Mar 17 19:54:17 2024 daemon.notice wpa_supplicant[2112]: Set new config for phy phy0
Sun Mar 17 19:54:18 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --set-ip-family ipv4 --set-client-id wds,17
Sun Mar 17 19:54:18 2024 daemon.notice hostapd: Set new config for phy phy0: /var/run/hostapd-phy0.conf
Sun Mar 17 19:54:18 2024 daemon.notice hostapd: Restart interface for phy phy0
Sun Mar 17 19:54:18 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --set-client-id wds,17 --start-network --apn mobile.o2.co.uk --profile 1 --auth-type none --username --password
Sun Mar 17 19:54:19 2024 daemon.notice netifd: mob1s1a1 (2846): pdh4: -512163984
Sun Mar 17 19:54:19 2024 daemon.notice netifd: mob1s1a1 (2846): -512163984
Sun Mar 17 19:54:19 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --get-client-id wds
Sun Mar 17 19:54:20 2024 daemon.notice hostapd: Configuration file: data: driver=nl80211 logger_syslog=127 logger_syslog_level=2 logger_stdout=127 logger_stdout_level=2 country_code=US ieee80211d=1 hw_mode=g supported_rates=60 90 120 180 240 360 480 540 basic_rates=60 120 240 beacon_int=100 dtim_period=2 noscan=1 #num_global_macaddr=1 ieee80211n=1 ht_coex=0 ht_capab=[LDPC][SHORT-GI-20][SHORT-GI-40][TX-STBC][RX-STBC1][DSSS_CCK-40] channel=acs_survey interface=wlan0 bssid=00:1e:42:30:06:12 ctrl_interface=/var/run/hostapd ap_isolate=1 bss_load_update_period=60 chan_util_avg_period=600 disassoc_low_ack=1 skip_inactivity_poll=0 preamble=1 wmm_enabled=1 ignore_broadcast_ssid=0 uapsd_advertisement_enabled=1 utf8_ssid=1 multi_ap=0 wpa_passphrase=Sugarlump1959% wpa_psk_file=/etc/hostapd/wlan0.psk auth_algs=1 wpa=2 wpa_pairwise=CCMP ssid=Freddies Wifi bridge=br-lan wpa_disable_eapol_key_retries=0 wpa_key_mgmt=WPA-PSK okc=0 disable_pmksa_caching=1 dynamic_vlan=0 vlan_naming=1 vlan_file=/var/run/hostapd-wlan0.vlan config_id=e76b46e62d1ca
Sun Mar 17 19:54:20 2024 daemon.notice netifd: mob1s1a1 (2846): 18
Sun Mar 17 19:54:20 2024 daemon.notice netifd: mob1s1a1 (2846): cid6: 18
Sun Mar 17 19:54:20 2024 kern.info kernel: [ 78.374774] br-lan: port 2(wlan0) entered blocking state
Sun Mar 17 19:54:20 2024 kern.info kernel: [ 78.380305] br-lan: port 2(wlan0) entered disabled state
Sun Mar 17 19:54:20 2024 kern.info kernel: [ 78.386246] device wlan0 entered promiscuous mode
Sun Mar 17 19:54:20 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --wds-bind-mux-data-port --mux-id 1 --ep-iface-number 4 --set-client-id wds,18
Sun Mar 17 19:54:20 2024 daemon.notice hostapd: wlan0: interface state UNINITIALIZED->COUNTRY_UPDATE
Sun Mar 17 19:54:20 2024 daemon.notice hostapd: ACS: Automatic channel selection started, this may take a bit
Sun Mar 17 19:54:20 2024 daemon.notice hostapd: wlan0: interface state COUNTRY_UPDATE->ACS
Sun Mar 17 19:54:20 2024 daemon.notice hostapd: wlan0: ACS-STARTED
Sun Mar 17 19:54:22 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --set-ip-family ipv6 --set-client-id wds,18
Sun Mar 17 19:54:23 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --set-client-id wds,18 --start-network --apn mobile.o2.co.uk --profile 1 --auth-type none --username --password
Sun Mar 17 19:54:24 2024 user.notice mobile.sh: QMI call error, reason type INTERNAL: “PDN IPv6 call disallowed” “Call failed”
Sun Mar 17 19:54:24 2024 daemon.notice netifd: mob1s1a1 (2846): pdh6: QMI call error, reason type INTERNAL: “PDN IPv6 call disallowed”
Sun Mar 17 19:54:24 2024 daemon.notice netifd: mob1s1a1 (2846): “Call failed”
Sun Mar 17 19:54:24 2024 daemon.notice netifd: mob1s1a1 (2846): Unable to connect IPv6
Sun Mar 17 19:54:24 2024 daemon.notice netifd: mob1s1a1 (2846): Releasing client-id 18 on /dev/cdc-wdm0
Sun Mar 17 19:54:25 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --set-client-id wds,18 --release-client-id wds
Sun Mar 17 19:54:25 2024 daemon.notice netifd: Interface ‘ifWan1’ is enabled
Sun Mar 17 19:54:26 2024 daemon.notice netifd: mob1s1a1 (2846): Setting up qmimux0
Sun Mar 17 19:54:26 2024 daemon.notice netifd: mob1s1a1 (2846): Setting dynamic MTU: 1500 on qmimux0
Sun Mar 17 19:54:27 2024 daemon.notice wpa_supplicant[2112]: Set new config for phy phy0
Sun Mar 17 19:54:29 2024 daemon.notice wpa_supplicant[2112]: wlan0-1: CTRL-EVENT-SCAN-FAILED ret=-16 retry=1
Sun Mar 17 19:54:29 2024 daemon.notice netifd: Interface ‘mob1s1a1’ is now up
Sun Mar 17 19:54:29 2024 daemon.notice netifd: Network device ‘wwan0’ link is up
Sun Mar 17 19:54:29 2024 user.notice mwan3-hotplug[2833]: mwan3 hotplug on lan not called because interface disabled
Sun Mar 17 19:54:30 2024 user.notice mwan3track[3809]: Interface wan (eth1) is online
Sun Mar 17 19:54:30 2024 daemon.notice netifd: mob1s1a1 (2846): Setting up qmimux0 V4 DCHP
Sun Mar 17 19:54:30 2024 daemon.notice netifd: Wireless device ‘radio0’ is now up
Sun Mar 17 19:54:30 2024 daemon.notice netifd: Interface ‘mob1s1a1_4’ is enabled
Sun Mar 17 19:54:30 2024 daemon.notice netifd: Network device ‘qmimux0’ link is up
Sun Mar 17 19:54:30 2024 daemon.notice netifd: Interface ‘mob1s1a1_4’ has link connectivity
Sun Mar 17 19:54:30 2024 daemon.notice netifd: Interface ‘mob1s1a1_4’ is setting up now
Sun Mar 17 19:54:31 2024 daemon.notice hostapd: wlan0: ACS-COMPLETED freq=2437 channel=6
Sun Mar 17 19:54:32 2024 kern.notice Port link state of port CPU/WiFi changed to UP
Sun Mar 17 19:54:32 2024 kern.notice Port speed for port CPU/WiFi changed to 1000 baseT
Sun Mar 17 19:54:32 2024 kern.notice Port link state of port WAN changed to UP
Sun Mar 17 19:54:32 2024 kern.notice Port speed for port WAN changed to 100 baseT
Sun Mar 17 19:54:33 2024 daemon.notice netifd: mob1s1a1_4 (4273): udhcpc: started, v1.34.1
Sun Mar 17 19:54:33 2024 kern.info kernel: [ 91.188071] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Sun Mar 17 19:54:33 2024 kern.info kernel: [ 91.194903] br-lan: port 2(wlan0) entered blocking state
Sun Mar 17 19:54:33 2024 kern.info kernel: [ 91.200392] br-lan: port 2(wlan0) entered forwarding state
Sun Mar 17 19:54:33 2024 daemon.notice netifd: Network device ‘wlan0’ link is up
Sun Mar 17 19:54:33 2024 daemon.notice hostapd: wlan0: interface state ACS->ENABLED
Sun Mar 17 19:54:33 2024 daemon.notice hostapd: wlan0: AP-ENABLED
Sun Mar 17 19:54:33 2024 daemon.notice wpa_supplicant[2112]: wlan0-1: CTRL-EVENT-SCAN-FAILED ret=-16 retry=1
Sun Mar 17 19:54:34 2024 daemon.notice netifd: mob1s1a1_4 (4273): udhcpc: broadcasting discover
Sun Mar 17 19:54:34 2024 daemon.notice netifd: mob1s1a1_4 (4273): udhcpc: broadcasting select for 10.150.169.99, server 10.150.169.100
Sun Mar 17 19:54:34 2024 daemon.notice netifd: mob1s1a1_4 (4273): udhcpc: lease of 10.150.169.99 obtained from 10.150.169.100, lease time 7200
Sun Mar 17 19:54:36 2024 daemon.notice wpa_supplicant[2112]: wlan0-1: SME: Trying to authenticate with 3c:7c:3f:55:d7:d0 (SSID=‘Moles_2.4G’ freq=2462 MHz)
Sun Mar 17 19:54:36 2024 daemon.notice netifd: Interface ‘mob1s1a1_4’ is now up
Sun Mar 17 19:54:36 2024 daemon.info dnsmasq[3495]: reading /tmp/resolv.conf.d/resolv.conf.auto
Sun Mar 17 19:54:36 2024 daemon.info dnsmasq[3495]: using only locally-known addresses for domain test
Sun Mar 17 19:54:36 2024 daemon.info dnsmasq[3495]: using only locally-known addresses for domain onion
Sun Mar 17 19:54:36 2024 daemon.info dnsmasq[3495]: using only locally-known addresses for domain localhost
Sun Mar 17 19:54:36 2024 daemon.info dnsmasq[3495]: using only locally-known addresses for domain invalid
Sun Mar 17 19:54:36 2024 daemon.info dnsmasq[3495]: using only locally-known addresses for domain bind
Sun Mar 17 19:54:36 2024 daemon.info dnsmasq[3495]: using only locally-known addresses for domain lan
Sun Mar 17 19:54:36 2024 daemon.info dnsmasq[3495]: using nameserver 192.168.88.1#53
Sun Mar 17 19:54:36 2024 daemon.info dnsmasq[3495]: using nameserver 82.132.254.2#53
Sun Mar 17 19:54:36 2024 daemon.info dnsmasq[3495]: using nameserver 82.132.254.3#53
Sun Mar 17 19:54:36 2024 kern.info kernel: [ 94.402022] wlan0-1: authenticate with 3c:7c:3f:55:d7:d0
Sun Mar 17 19:54:36 2024 daemon.notice wpa_supplicant[2112]: wlan0-1: SME: Authentication request to the driver failed
Sun Mar 17 19:54:37 2024 daemon.info hostapd: wlan0: IEEE 802.11 driver starting channel switch: iface->freq=2437, freq=2462, ht=1, vht_ch=0x0, he_ch=0x0, eht_ch=0x0, offset=0, width=1 (20 MHz), cf1=2462, cf2=0, puncturing_bitmap=0x0
Sun Mar 17 19:54:37 2024 daemon.notice hostapd: wlan0: CTRL-EVENT-STARTED-CHANNEL-SWITCH freq=2462 ht_enabled=1 ch_offset=0 ch_width=20 MHz cf1=2462 cf2=0 is_dfs0=0 dfs=0 puncturing_bitmap=0x0000
Sun Mar 17 19:54:37 2024 daemon.info mobifd: Connection setup completed for ‘mob1s1a1’
Sun Mar 17 19:54:37 2024 user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Sun Mar 17 19:54:38 2024 daemon.notice wpa_supplicant[2112]: wlan0-1: SME: Trying to authenticate with 3c:7c:3f:55:d7:d0 (SSID=‘Moles_2.4G’ freq=2462 MHz)
Sun Mar 17 19:54:39 2024 kern.notice ip_blockd service is enabled, initialized firewall rules
Sun Mar 17 19:54:39 2024 daemon.info hostapd: wlan0: IEEE 802.11 driver had channel switch: iface->freq=2462, freq=2462, ht=1, vht_ch=0x0, he_ch=0x0, eht_ch=0x0, offset=0, width=1 (20 MHz), cf1=2462, cf2=0, puncturing_bitmap=0x0
Sun Mar 17 19:54:39 2024 daemon.notice hostapd: wlan0: CTRL-EVENT-CHANNEL-SWITCH freq=2462 ht_enabled=1 ch_offset=0 ch_width=20 MHz cf1=2462 cf2=0 is_dfs0=0 dfs=0 puncturing_bitmap=0x0000
Sun Mar 17 19:54:39 2024 daemon.notice hostapd: wlan0: AP-CSA-FINISHED freq=2462 dfs=0
Sun Mar 17 19:54:39 2024 kern.info kernel: [ 96.958314] wlan0-1: authenticate with 3c:7c:3f:55:d7:d0
Sun Mar 17 19:54:39 2024 kern.info kernel: [ 96.972855] wlan0-1: send auth to 3c:7c:3f:55:d7:d0 (try 1/3)
Sun Mar 17 19:54:39 2024 kern.info kernel: [ 96.981529] wlan0-1: authenticated
Sun Mar 17 19:54:39 2024 daemon.notice wpa_supplicant[2112]: wlan0-1: Trying to associate with 3c:7c:3f:55:d7:d0 (SSID=‘Moles_2.4G’ freq=2462 MHz)
Sun Mar 17 19:54:39 2024 kern.info kernel: [ 97.698152] wlan0-1: associate with 3c:7c:3f:55:d7:d0 (try 1/3)
Sun Mar 17 19:54:40 2024 kern.info kernel: [ 97.738141] wlan0-1: RX AssocResp from 3c:7c:3f:55:d7:d0 (capab=0x1411 status=0 aid=25)
Sun Mar 17 19:54:40 2024 kern.info kernel: [ 97.746777] wlan0-1: associated
Sun Mar 17 19:54:40 2024 daemon.notice netifd: Network device ‘wlan0-1’ link is up
Sun Mar 17 19:54:40 2024 daemon.notice netifd: Interface ‘ifWan1’ has link connectivity
Sun Mar 17 19:54:40 2024 daemon.notice netifd: Interface ‘ifWan1’ is setting up now
Sun Mar 17 19:54:40 2024 kern.debug kernel: [ 97.878673] wlan0-1: Limiting TX power to 20 (20 - 0) dBm as advertised by 3c:7c:3f:55:d7:d0
Sun Mar 17 19:54:40 2024 user.info kernel: [ 98.107389] kmodloader: loading kernel modules from /etc/modules-late.d/*
Sun Mar 17 19:54:40 2024 daemon.notice wpa_supplicant[2112]: wlan0-1: Associated with 3c:7c:3f:55:d7:d0
Sun Mar 17 19:54:40 2024 daemon.notice wpa_supplicant[2112]: wlan0-1: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Sun Mar 17 19:54:41 2024 daemon.notice netifd: ifWan1 (4589): udhcpc: started, v1.34.1
Sun Mar 17 19:54:42 2024 daemon.notice wpa_supplicant[2112]: wlan0-1: WPA: Key negotiation completed with 3c:7c:3f:55:d7:d0 [PTK=CCMP GTK=CCMP]
Sun Mar 17 19:54:42 2024 daemon.notice wpa_supplicant[2112]: wlan0-1: CTRL-EVENT-CONNECTED - Connection to 3c:7c:3f:55:d7:d0 completed [id=0 id_str=]
Sun Mar 17 19:54:42 2024 kern.info kernel: [ 99.859307] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0-1: link becomes ready
Sun Mar 17 19:54:42 2024 daemon.notice netifd: ifWan1 (4589): udhcpc: broadcasting discover
Sun Mar 17 19:54:43 2024 kern.info kernel: [ 101.402264] mmc_spi spi0.1: SD/MMC host mmc0, no WP, no poweroff, cd polling
Sun Mar 17 19:54:43 2024 kern.warn kernel: [ 101.415711] mmc_spi spi0.1: no card detected
Sun Mar 17 19:54:43 2024 kern.err kernel: [ 101.420171] mmc0: error -22 whilst initialising SD card
Sun Mar 17 19:54:43 2024 user.info kernel: [ 101.446587] kmodloader: done loading kernel modules from /etc/modules-late.d/*
Sun Mar 17 19:54:44 2024 user.info mwan3track[3809]: Check (ping) failed for target “1.1.1.1” on interface wan (eth1). Current score: 6
Sun Mar 17 19:54:45 2024 daemon.notice netifd: ifWan1 (4589): udhcpc: broadcasting discover
Sun Mar 17 19:54:45 2024 user.notice mwan3-hotplug[4654]: mwan3 hotplug on loopback not called because interface disabled
Sun Mar 17 19:54:46 2024 cron.err crond[4761]: crond (busybox 1.34.1) started, log level 5
Sun Mar 17 19:54:46 2024 user.info mwan3track[3809]: Check (ping) failed for target “8.8.8.8” on interface wan (eth1). Current score: 6
Sun Mar 17 19:54:46 2024 user.notice mwan3track[3809]: Interface wan (eth1) is disconnecting
Sun Mar 17 19:54:48 2024 daemon.notice netifd: ifWan1 (4589): udhcpc: broadcasting discover
Sun Mar 17 19:54:48 2024 daemon.notice netifd: ifWan1 (4589): udhcpc: broadcasting select for 192.168.50.232, server 192.168.50.1
Sun Mar 17 19:54:48 2024 daemon.notice netifd: ifWan1 (4589): udhcpc: lease of 192.168.50.232 obtained from 192.168.50.1, lease time 86400
Sun Mar 17 19:54:49 2024 daemon.notice netifd: Interface ‘ifWan1’ is now up
Sun Mar 17 19:54:49 2024 daemon.info dnsmasq[3495]: reading /tmp/resolv.conf.d/resolv.conf.auto
Sun Mar 17 19:54:49 2024 daemon.info dnsmasq[3495]: using only locally-known addresses for domain test
Sun Mar 17 19:54:49 2024 daemon.info dnsmasq[3495]: using only locally-known addresses for domain onion
Sun Mar 17 19:54:49 2024 daemon.info dnsmasq[3495]: using only locally-known addresses for domain localhost
Sun Mar 17 19:54:49 2024 daemon.info dnsmasq[3495]: using only locally-known addresses for domain invalid
Sun Mar 17 19:54:49 2024 daemon.info dnsmasq[3495]: using only locally-known addresses for domain bind
Sun Mar 17 19:54:49 2024 daemon.info dnsmasq[3495]: using only locally-known addresses for domain lan
Sun Mar 17 19:54:49 2024 daemon.info dnsmasq[3495]: using nameserver 192.168.88.1#53
Sun Mar 17 19:54:49 2024 daemon.info dnsmasq[3495]: using nameserver 82.132.254.2#53
Sun Mar 17 19:54:49 2024 daemon.info dnsmasq[3495]: using nameserver 82.132.254.3#53
Sun Mar 17 19:54:49 2024 daemon.info dnsmasq[3495]: using nameserver 192.168.50.1#53
Sun Mar 17 19:54:55 2024 cron.err crond[5253]: crond (busybox 1.34.1) started, log level 5
Sun Mar 17 19:54:56 2024 user.notice mwan3-hotplug[4995]: Execute ifup event on interface wan (eth1)
Sun Mar 17 19:54:58 2024 user.info mwan3track[3809]: Check (ping) failed for target “1.1.1.1” on interface wan (eth1). Current score: 5
Sun Mar 17 19:55:00 2024 user.info mwan3track[3809]: Check (ping) failed for target “8.8.8.8” on interface wan (eth1). Current score: 5
Sun Mar 17 19:55:04 2024 kern.info Switched to backup WAN (wan)
Sun Mar 17 19:55:04 2024 user.info mwan3track[3809]: Detect ifup event on interface wan (eth1)
Sun Mar 17 19:55:04 2024 user.info mwan3track[3809]: Check (ping) failed for target “1.1.1.1” on interface wan (eth1). Current score: 4
Sun Mar 17 19:55:07 2024 user.info mwan3track[3809]: Check (ping) failed for target “8.8.8.8” on interface wan (eth1). Current score: 4
Sun Mar 17 19:55:07 2024 user.notice mwan3track[3809]: Interface wan (eth1) is offline
Sun Mar 17 19:55:08 2024 user.notice firewall: Reloading firewall due to ifup of wan (eth1)
Sun Mar 17 19:55:09 2024 daemon.info hostapd: wlan0: STA a6:59:78:af:45:09 IEEE 802.11: authenticated
Sun Mar 17 19:55:09 2024 daemon.info hostapd: wlan0: STA a6:59:78:af:45:09 IEEE 802.11: associated (aid 1)
Sun Mar 17 19:55:09 2024 daemon.notice hostapd: wlan0: AP-STA-CONNECTED a6:59:78:af:45:09 auth_alg=open
Sun Mar 17 19:55:09 2024 kern.notice Freddies Wifi: WiFi client connected: A6:59:78:AF:45:09
Sun Mar 17 19:55:09 2024 daemon.info hostapd: wlan0: STA a6:59:78:af:45:09 RADIUS: starting accounting session E668D63B26B32F37
Sun Mar 17 19:55:09 2024 daemon.info hostapd: wlan0: STA a6:59:78:af:45:09 WPA: pairwise key handshake completed (RSN)
Sun Mar 17 19:55:09 2024 daemon.notice hostapd: wlan0: EAPOL-4WAY-HS-COMPLETED a6:59:78:af:45:09
Sun Mar 17 19:55:09 2024 daemon.info dnsmasq-dhcp[3495]: DHCPREQUEST(br-lan) 192.168.1.152 a6:59:78:af:45:09
Sun Mar 17 19:55:09 2024 daemon.info dnsmasq-dhcp[3495]: DHCPACK(br-lan) 192.168.1.152 a6:59:78:af:45:09
Sun Mar 17 19:55:12 2024 user.info mwan3-hotplug[5922]: Connection tracking flushed for interface ‘wan’ on action ‘disconnected’
Sun Mar 17 19:55:12 2024 user.notice mwan3-hotplug[5922]: Execute disconnected event on interface wan (eth1)
Sun Mar 17 19:55:15 2024 daemon.notice procd: /etc/rc.d/S96ledman: setting up led LAN1
Sun Mar 17 19:55:16 2024 daemon.notice procd: /etc/rc.d/S96ledman: setting up led LAN2
Sun Mar 17 19:55:16 2024 daemon.notice procd: /etc/rc.d/S96ledman: setting up led LAN3
Sun Mar 17 19:55:17 2024 daemon.notice procd: /etc/rc.d/S96ledman: setting up led WAN
Sun Mar 17 19:55:17 2024 cron.err crond[6347]: crond (busybox 1.34.1) started, log level 5
Sun Mar 17 19:55:20 2024 kern.info WAN (wan) is down, no more backups to switch
Sun Mar 17 19:55:23 2024 user.notice mwan3-hotplug[6363]: Execute ifup event on interface mob1s1a1 (wwan0)
Sun Mar 17 19:55:27 2024 daemon.notice hostapd: wlan0: AP-STA-DISCONNECTED a6:59:78:af:45:09
Sun Mar 17 19:55:27 2024 kern.notice Freddies Wifi: WiFi client disconnected: A6:59:78:AF:45:09
Sun Mar 17 19:55:27 2024 daemon.info hostapd: wlan0: STA a6:59:78:af:45:09 IEEE 802.11: disassociated
Sun Mar 17 19:55:28 2024 daemon.info hostapd: wlan0: STA a6:59:78:af:45:09 IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Sun Mar 17 19:55:31 2024 kern.info Switched to backup WAN (mob1s1a1)
Sun Mar 17 19:55:31 2024 user.info mwan3track[3810]: Detect ifup event on interface mob1s1a1 ()
Sun Mar 17 19:55:31 2024 daemon.info hostapd: wlan0: STA a6:59:78:af:45:09 IEEE 802.11: authenticated
Sun Mar 17 19:55:31 2024 daemon.info hostapd: wlan0: STA a6:59:78:af:45:09 IEEE 802.11: associated (aid 1)
Sun Mar 17 19:55:31 2024 daemon.notice hostapd: wlan0: AP-STA-CONNECTED a6:59:78:af:45:09 auth_alg=open
Sun Mar 17 19:55:31 2024 kern.notice Freddies Wifi: WiFi client connected: A6:59:78:AF:45:09
Sun Mar 17 19:55:31 2024 daemon.info hostapd: wlan0: STA a6:59:78:af:45:09 RADIUS: starting accounting session E4F7B39304CC5904
Sun Mar 17 19:55:31 2024 daemon.info hostapd: wlan0: STA a6:59:78:af:45:09 WPA: pairwise key handshake completed (RSN)
Sun Mar 17 19:55:31 2024 daemon.notice hostapd: wlan0: EAPOL-4WAY-HS-COMPLETED a6:59:78:af:45:09
Sun Mar 17 19:55:32 2024 daemon.info dnsmasq-dhcp[3495]: DHCPREQUEST(br-lan) 192.168.1.152 a6:59:78:af:45:09
Sun Mar 17 19:55:32 2024 daemon.info dnsmasq-dhcp[3495]: DHCPACK(br-lan) 192.168.1.152 a6:59:78:af:45:09
Sun Mar 17 19:55:33 2024 user.info mwan3track[3810]: Check (ping) failed for target “1.1.1.1” on interface mob1s1a1 (). Current score: 6
Sun Mar 17 19:55:36 2024 user.notice mwan3track[3809]: Interface wan (eth1) is online
Sun Mar 17 19:55:36 2024 user.info mwan3track[3810]: Check (ping) failed for target “8.8.8.8” on interface mob1s1a1 (). Current score: 6
Sun Mar 17 19:55:36 2024 user.notice mwan3track[3810]: Interface mob1s1a1 () is disconnecting
Sun Mar 17 19:55:37 2024 user.notice firewall: Reloading firewall due to ifup of mob1s1a1 (wwan0)
Sun Mar 17 19:55:44 2024 user.info mwan3track[3809]: Check (ping) failed for target “1.1.1.1” on interface wan (eth1). Current score: 6
Sun Mar 17 19:56:53 2024 kern.warn kernel: [ 164.270525] process ‘ntpclient’ launched ‘/usr/sbin/ntpd-hotplug’ with NULL argv: empty string added
Sun Mar 17 19:56:54 2024 user.info mwan3track[3809]: Check (ping) failed for target “8.8.8.8” on interface wan (eth1). Current score: 6
Sun Mar 17 19:56:54 2024 user.notice mwan3track[3809]: Interface wan (eth1) is disconnecting
Sun Mar 17 19:57:00 2024 daemon.info dnsmasq[3495]: exiting on receipt of SIGTERM
Sun Mar 17 19:57:00 2024 daemon.info dnsmasq[8188]: Connected to system UBus
Sun Mar 17 19:57:00 2024 daemon.info dnsmasq[8188]: started, version 2.85 cachesize 150
Sun Mar 17 19:57:00 2024 daemon.info dnsmasq[8188]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-regex no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-cryptohash no-DNSSEC no-ID loop-detect inotify dumpfile
Sun Mar 17 19:57:00 2024 daemon.info dnsmasq[8188]: UBus support enabled: connected to system bus
Sun Mar 17 19:57:00 2024 daemon.info dnsmasq-dhcp[8188]: DHCP, IP range 192.168.1.100 – 192.168.1.249, lease time 12h
Sun Mar 17 19:57:00 2024 daemon.info dnsmasq[8188]: using only locally-known addresses for domain test
Sun Mar 17 19:57:00 2024 daemon.info dnsmasq[8188]: using only locally-known addresses for domain onion
Sun Mar 17 19:57:00 2024 daemon.info dnsmasq[8188]: using only locally-known addresses for domain localhost
Sun Mar 17 19:57:00 2024 daemon.info dnsmasq[8188]: using only locally-known addresses for domain invalid
Sun Mar 17 19:57:00 2024 daemon.info dnsmasq[8188]: using only locally-known addresses for domain bind
Sun Mar 17 19:57:00 2024 daemon.info dnsmasq[8188]: using only locally-known addresses for domain lan
Sun Mar 17 19:57:00 2024 daemon.info dnsmasq[8188]: reading /tmp/resolv.conf.d/resolv.conf.auto
Sun Mar 17 19:57:00 2024 daemon.info dnsmasq[8188]: using nameserver 192.168.88.1#53
Sun Mar 17 19:57:00 2024 daemon.info dnsmasq[8188]: using nameserver 82.132.254.2#53
Sun Mar 17 19:57:00 2024 daemon.info dnsmasq[8188]: using nameserver 82.132.254.3#53
Sun Mar 17 19:57:00 2024 daemon.info dnsmasq[8188]: using nameserver 192.168.50.1#53
Sun Mar 17 19:57:00 2024 daemon.info dnsmasq[8188]: read /etc/hosts - 4 addresses
Sun Mar 17 19:57:00 2024 daemon.info dnsmasq[8188]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Sun Mar 17 19:57:00 2024 daemon.info dnsmasq-dhcp[8188]: read /etc/ethers - 0 addresses
Sun Mar 17 19:57:04 2024 user.notice mwan3track[3810]: Interface mob1s1a1 (qmimux0) is online
Sun Mar 17 19:57:05 2024 user.info mwan3track[3809]: Check (ping) failed for target “1.1.1.1” on interface wan (eth1). Current score: 5
Sun Mar 17 19:57:07 2024 user.info mwan3track[3809]: Check (ping) failed for target “8.8.8.8” on interface wan (eth1). Current score: 5
Sun Mar 17 19:57:08 2024 daemon.info dnsmasq[8188]: read /etc/hosts - 4 addresses
Sun Mar 17 19:57:08 2024 daemon.info dnsmasq[8188]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Sun Mar 17 19:57:08 2024 daemon.info dnsmasq-dhcp[8188]: read /etc/ethers - 0 addresses
Sun Mar 17 19:57:13 2024 user.info mwan3track[3809]: Check (ping) failed for target “1.1.1.1” on interface wan (eth1). Current score: 4
Sun Mar 17 19:57:15 2024 daemon.info procd: - init complete -
Sun Mar 17 19:57:15 2024 daemon.info dfota[6856]: Searching for WAN…
Sun Mar 17 19:57:15 2024 user.notice mwan3-hotplug[8619]: mwan3 hotplug on mob1s1a1_4 not called because interface disabled
Sun Mar 17 19:57:15 2024 user.info mwan3track[3809]: Check (ping) failed for target “8.8.8.8” on interface wan (eth1). Current score: 4
Sun Mar 17 19:57:15 2024 daemon.info dfota[6856]: WAN found on interface: ifWan1
Sun Mar 17 19:57:15 2024 kern.notice Password auth succeeded for admin on HTTP from 192.168.1.152
Sun Mar 17 19:57:15 2024 daemon.err uhttpd[2496]: vuci: accepted login for admin from 192.168.1.152
Sun Mar 17 19:57:16 2024 daemon.info dfota[6856]: Preparing for gsm.modem0 update!
Sun Mar 17 19:57:16 2024 user.notice mwan3track[3809]: Interface wan (eth1) is offline
Sun Mar 17 19:57:16 2024 daemon.info dfota[6856]: Searching for updates…
Sun Mar 17 19:57:18 2024 daemon.info dnsmasq[8188]: read /etc/hosts - 4 addresses
Sun Mar 17 19:57:18 2024 daemon.info dnsmasq[8188]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Sun Mar 17 19:57:18 2024 daemon.info dnsmasq-dhcp[8188]: read /etc/ethers - 0 addresses
Sun Mar 17 19:57:21 2024 user.notice firewall: Reloading firewall due to ifup of mob1s1a1_4 (qmimux0)
Sun Mar 17 19:57:22 2024 user.info mwan3-hotplug[8850]: Connection tracking flushed for interface ‘wan’ on action ‘disconnected’
Sun Mar 17 19:57:22 2024 user.notice mwan3-hotplug[8850]: Execute disconnected event on interface wan (eth1)
Sun Mar 17 19:57:32 2024 daemon.info dfota[6856]: No update found!
Sun Mar 17 19:57:37 2024 daemon.info dnsmasq[8188]: read /etc/hosts - 4 addresses
Sun Mar 17 19:57:37 2024 daemon.info dnsmasq[8188]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Sun Mar 17 19:57:37 2024 daemon.info dnsmasq-dhcp[8188]: read /etc/ethers - 0 addresses
Sun Mar 17 19:57:42 2024 kern.info Mobile data connected (internal modem)
Sun Mar 17 19:57:42 2024 kern.info Joined LTE network (internal modem)
Sun Mar 17 19:57:43 2024 kern.info Connected to O2 - UK giffgaff operator (internal modem)
Sun Mar 17 19:57:45 2024 cron.err crond[9841]: crond (busybox 1.34.1) started, log level 5
Sun Mar 17 19:57:45 2024 cron.err crond[9841]: ignoring file ‘rootaHaFdJ’ (no such user)
Sun Mar 17 19:57:46 2024 daemon.info dfota[6856]: Update script done!
Sun Mar 17 19:57:50 2024 cron.err crond[10018]: crond (busybox 1.34.1) started, log level 5
Sun Mar 17 19:57:50 2024 user.notice mwan3-hotplug[9791]: Execute ifup event on interface ifWan1 (wlan0-1)
Sun Mar 17 19:57:56 2024 kern.info Switched to main WAN (ifWan1)
Sun Mar 17 19:57:56 2024 user.info mwan3track[3811]: Detect ifup event on interface ifWan1 ()
Sun Mar 17 19:57:58 2024 user.notice firewall: Reloading firewall due to ifup of ifWan1 (wlan0-1)
Sun Mar 17 19:57:58 2024 user.info mwan3track[3811]: Check (ping) failed for target “1.1.1.1” on interface ifWan1 (). Current score: 6
Sun Mar 17 19:58:00 2024 user.info mwan3track[3811]: Check (ping) failed for target “8.8.8.8” on interface ifWan1 (). Current score: 6
Sun Mar 17 19:58:00 2024 user.notice mwan3track[3811]: Interface ifWan1 () is disconnecting
Sun Mar 17 19:58:04 2024 user.notice mwan3track[3811]: Interface ifWan1 (wlan0-1) is online
Sun Mar 17 19:59:15 2024 kern.notice kernel: periodic_reboot configuration has been changed
Sun Mar 17 19:59:18 2024 cron.err crond[11426]: crond (busybox 1.34.1) started, log level 5
Sun Mar 17 19:59:53 2024 kern.notice kernel: periodic_reboot configuration has been changed
Sun Mar 17 19:59:56 2024 cron.err crond[11794]: crond (busybox 1.34.1) started, log level 5
Sun Mar 17 20:00:01 2024 kern.notice kernel: periodic_reboot configuration has been changed
Sun Mar 17 20:00:04 2024 cron.err crond[11978]: crond (busybox 1.34.1) started, log level 5
Sun Mar 17 20:00:19 2024 daemon.notice netifd: wan (2874): udhcpc: sending renew to server 192.168.88.1
Sun Mar 17 20:00:19 2024 daemon.notice netifd: wan (2874): udhcpc: lease of 192.168.88.254 obtained from 192.168.88.1, lease time 600
Sun Mar 17 20:01:11 2024 user.info mwan3track[3811]: Check (ping) failed for target “1.1.1.1” on interface ifWan1 (wlan0-1). Current score: 6
Sun Mar 17 20:02:30 2024 user.info mwan3track[3810]: Check (ping) failed for target “1.1.1.1” on interface mob1s1a1 (qmimux0). Current score: 6
Sun Mar 17 20:02:35 2024 user.info mwan3track[3810]: Check (ping) failed for target “1.1.1.1” on interface mob1s1a1 (qmimux0). Current score: 6
Sun Mar 17 20:03:07 2024 daemon.notice hostapd: wlan0: AP-STA-DISCONNECTED a6:59:78:af:45:09
Sun Mar 17 20:03:07 2024 kern.notice Freddies Wifi: WiFi client disconnected: A6:59:78:AF:45:09
Sun Mar 17 20:03:07 2024 daemon.info hostapd: wlan0: STA a6:59:78:af:45:09 IEEE 802.11: disassociated
Sun Mar 17 20:03:07 2024 user.info : Starting database size optimization…
Sun Mar 17 20:03:08 2024 daemon.info hostapd: wlan0: STA a6:59:78:af:45:09 IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Sun Mar 17 20:03:36 2024 daemon.info hostapd: wlan0: STA a6:59:78:af:45:09 IEEE 802.11: authenticated
Sun Mar 17 20:03:36 2024 daemon.info hostapd: wlan0: STA a6:59:78:af:45:09 IEEE 802.11: associated (aid 1)
Sun Mar 17 20:03:36 2024 daemon.notice hostapd: wlan0: AP-STA-CONNECTED a6:59:78:af:45:09 auth_alg=open
Sun Mar 17 20:03:36 2024 kern.notice Freddies Wifi: WiFi client connected: A6:59:78:AF:45:09
Sun Mar 17 20:03:36 2024 daemon.info hostapd: wlan0: STA a6:59:78:af:45:09 RADIUS: starting accounting session CF22B8130D3FF6EB
Sun Mar 17 20:03:36 2024 daemon.info hostapd: wlan0: STA a6:59:78:af:45:09 WPA: pairwise key handshake completed (RSN)
Sun Mar 17 20:03:36 2024 daemon.notice hostapd: wlan0: EAPOL-4WAY-HS-COMPLETED a6:59:78:af:45:09
Sun Mar 17 20:03:36 2024 daemon.info dnsmasq-dhcp[8188]: DHCPREQUEST(br-lan) 192.168.1.152 a6:59:78:af:45:09
Sun Mar 17 20:03:36 2024 daemon.info dnsmasq-dhcp[8188]: DHCPACK(br-lan) 192.168.1.152 a6:59:78:af:45:09
Sun Mar 17 20:03:48 2024 user.info : Finished database optimization
Sun Mar 17 20:04:11 2024 user.info mwan3track[3810]: Check (ping) failed for target “1.1.1.1” on interface mob1s1a1 (qmimux0). Current score: 6
Sun Mar 17 20:04:12 2024 kern.notice Password auth succeeded for admin on HTTP from 192.168.1.152
Sun Mar 17 20:04:12 2024 daemon.err uhttpd[2496]: vuci: accepted login for admin from 192.168.1.152
Sun Mar 17 20:04:26 2024 kern.notice kernel: periodic_reboot configuration has been changed
Sun Mar 17 20:04:29 2024 cron.err crond[13624]: crond (busybox 1.34.1) started, log level 5
Sun Mar 17 20:04:43 2024 kern.notice Password auth succeeded for admin on HTTP from 192.168.1.152
Sun Mar 17 20:04:43 2024 daemon.err uhttpd[2496]: vuci: accepted login for admin from 192.168.1.152
Sun Mar 17 20:05:18 2024 daemon.notice netifd: wan (2874): udhcpc: sending renew to server 192.168.88.1
Sun Mar 17 20:05:18 2024 daemon.notice netifd: wan (2874): udhcpc: lease of 192.168.88.254 obtained from 192.168.88.1, lease time 600
Sun Mar 17 20:05:22 2024 kern.notice kernel: network configuration has been changed
Sun Mar 17 20:05:23 2024 kern.notice kernel: mwan3 configuration has been changed
Sun Mar 17 20:05:26 2024 daemon.notice netifd: Wireless device ‘radio0’ set retry=3
Sun Mar 17 20:05:27 2024 daemon.notice netifd: wan (2874): udhcpc: received SIGTERM
Sun Mar 17 20:05:27 2024 daemon.notice netifd: wan (2874): udhcpc: unicasting a release of 192.168.88.254 to 192.168.88.1
Sun Mar 17 20:05:27 2024 daemon.notice netifd: wan (2874): udhcpc: sending release
Sun Mar 17 20:05:27 2024 daemon.notice netifd: wan (2874): udhcpc: entering released state
Sun Mar 17 20:05:28 2024 daemon.notice netifd: wan (2874): Command failed: Permission denied
Sun Mar 17 20:05:28 2024 daemon.notice netifd: Interface ‘wan’ is now down
Sun Mar 17 20:05:28 2024 daemon.info dnsmasq[8188]: reading /tmp/resolv.conf.d/resolv.conf.auto
Sun Mar 17 20:05:28 2024 daemon.info dnsmasq[8188]: using only locally-known addresses for domain test
Sun Mar 17 20:05:28 2024 daemon.notice netifd: Interface ‘wan’ has link connectivity loss
Sun Mar 17 20:05:28 2024 daemon.info dnsmasq[8188]: using only locally-known addresses for domain onion
Sun Mar 17 20:05:28 2024 daemon.info dnsmasq[8188]: using only locally-known addresses for domain localhost
Sun Mar 17 20:05:28 2024 daemon.info dnsmasq[8188]: using only locally-known addresses for domain invalid
Sun Mar 17 20:05:28 2024 daemon.info dnsmasq[8188]: using only locally-known addresses for domain bind
Sun Mar 17 20:05:28 2024 daemon.info dnsmasq[8188]: using only locally-known addresses for domain lan
Sun Mar 17 20:05:28 2024 daemon.info dnsmasq[8188]: using nameserver 82.132.254.2#53
Sun Mar 17 20:05:28 2024 daemon.info dnsmasq[8188]: using nameserver 82.132.254.3#53
Sun Mar 17 20:05:28 2024 daemon.info dnsmasq[8188]: using nameserver 192.168.50.1#53
Sun Mar 17 20:05:28 2024 daemon.notice hostapd: wlan0: AP-STA-DISCONNECTED a6:59:78:af:45:09
Sun Mar 17 20:05:28 2024 kern.notice Freddies Wifi: WiFi client disconnected: A6:59:78:AF:45:09
Sun Mar 17 20:05:28 2024 daemon.info hostapd: wlan0: STA a6:59:78:af:45:09 IEEE 802.11: authenticated
Sun Mar 17 20:05:28 2024 daemon.info hostapd: wlan0: STA a6:59:78:af:45:09 IEEE 802.11: associated (aid 1)
Sun Mar 17 20:05:28 2024 daemon.notice hostapd: wlan0: AP-STA-CONNECTED a6:59:78:af:45:09 auth_alg=open
Sun Mar 17 20:05:28 2024 kern.notice Freddies Wifi: WiFi client connected: A6:59:78:AF:45:09
Sun Mar 17 20:05:28 2024 daemon.info hostapd: wlan0: STA a6:59:78:af:45:09 RADIUS: starting accounting session CF22B8130D3FF6EB
Sun Mar 17 20:05:28 2024 daemon.info hostapd: wlan0: STA a6:59:78:af:45:09 WPA: pairwise key handshake completed (RSN)
Sun Mar 17 20:05:28 2024 daemon.notice hostapd: wlan0: EAPOL-4WAY-HS-COMPLETED a6:59:78:af:45:09
Sun Mar 17 20:05:31 2024 user.notice mwan3-hotplug[14407]: mwan3 hotplug on wan not called because interface disabled
Sun Mar 17 20:05:38 2024 daemon.info dnsmasq[8188]: exiting on receipt of SIGTERM
Sun Mar 17 20:05:38 2024 daemon.info dnsmasq[14756]: Connected to system UBus
Sun Mar 17 20:05:38 2024 daemon.info dnsmasq[14756]: started, version 2.85 cachesize 150
Sun Mar 17 20:05:38 2024 daemon.info dnsmasq[14756]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-regex no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-cryptohash no-DNSSEC no-ID loop-detect inotify dumpfile
Sun Mar 17 20:05:38 2024 daemon.info dnsmasq[14756]: UBus support enabled: connected to system bus
Sun Mar 17 20:05:38 2024 daemon.info dnsmasq-dhcp[14756]: DHCP, IP range 192.168.1.100 – 192.168.1.249, lease time 12h
Sun Mar 17 20:05:38 2024 daemon.info dnsmasq[14756]: using only locally-known addresses for domain test
Sun Mar 17 20:05:38 2024 daemon.info dnsmasq[14756]: using only locally-known addresses for domain onion
Sun Mar 17 20:05:38 2024 daemon.info dnsmasq[14756]: using only locally-known addresses for domain localhost
Sun Mar 17 20:05:38 2024 daemon.info dnsmasq[14756]: using only locally-known addresses for domain invalid
Sun Mar 17 20:05:38 2024 daemon.info dnsmasq[14756]: using only locally-known addresses for domain bind
Sun Mar 17 20:05:38 2024 daemon.info dnsmasq[14756]: using only locally-known addresses for domain lan
Sun Mar 17 20:05:38 2024 daemon.info dnsmasq[14756]: reading /tmp/resolv.conf.d/resolv.conf.auto
Sun Mar 17 20:05:38 2024 daemon.info dnsmasq[14756]: using nameserver 82.132.254.2#53
Sun Mar 17 20:05:38 2024 daemon.info dnsmasq[14756]: using nameserver 82.132.254.3#53
Sun Mar 17 20:05:38 2024 daemon.info dnsmasq[14756]: using nameserver 192.168.50.1#53
Sun Mar 17 20:05:38 2024 daemon.info dnsmasq[14756]: read /etc/hosts - 4 addresses
Sun Mar 17 20:05:38 2024 daemon.info dnsmasq[14756]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Sun Mar 17 20:05:38 2024 daemon.info dnsmasq-dhcp[14756]: read /etc/ethers - 0 addresses
Sun Mar 17 20:05:39 2024 daemon.info dnsmasq[14756]: read /etc/hosts - 4 addresses
Sun Mar 17 20:05:39 2024 daemon.info dnsmasq[14756]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Sun Mar 17 20:05:39 2024 daemon.info dnsmasq-dhcp[14756]: read /etc/ethers - 0 addresses
Sun Mar 17 20:05:44 2024 user.notice mwan3track[3809]: Stopping mwan3track for interface “wan”. Status was “offline”
Sun Mar 17 20:05:44 2024 user.notice mwan3track[3811]: Stopping mwan3track for interface “ifWan1”. Status was “online”
Sun Mar 17 20:05:44 2024 user.notice mwan3track[3810]: Stopping mwan3track for interface “mob1s1a1”. Status was “online”
Sun Mar 17 20:05:48 2024 user.notice mwan3-hotplug[15045]: Execute ifup event on interface mob1s1a1 (qmimux0)
Sun Mar 17 20:05:49 2024 user.notice mwan3-hotplug[15055]: Execute ifup event on interface ifWan1 (wlan0-1)
Sun Mar 17 20:05:53 2024 daemon.err dnsmasq[14756]: failed to send packet: Network unreachable
Sun Mar 17 20:05:54 2024 daemon.err dnsmasq[14756]: failed to send packet: Network unreachable
Sun Mar 17 20:05:55 2024 daemon.err dnsmasq[14756]: failed to send packet: Network unreachable
Sun Mar 17 20:05:56 2024 daemon.err dnsmasq[14756]: failed to send packet: Network unreachable
Sun Mar 17 20:05:58 2024 daemon.err dnsmasq[14756]: failed to send packet: Network unreachable
Sun Mar 17 20:05:59 2024 user.notice mwan3track[15445]: Interface ifWan1 (wlan0-1) is online
Sun Mar 17 20:05:59 2024 user.notice mwan3track[15444]: Interface mob1s1a1 (qmimux0) is online
Sun Mar 17 20:06:07 2024 daemon.info dnsmasq[14756]: read /etc/hosts - 4 addresses
Sun Mar 17 20:06:07 2024 daemon.info dnsmasq[14756]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Sun Mar 17 20:06:07 2024 daemon.info dnsmasq-dhcp[14756]: read /etc/ethers - 0 addresses
Sun Mar 17 20:07:37 2024 user.info mwan3track[15444]: Check (ping) failed for target “1.1.1.1” on interface mob1s1a1 (qmimux0). Current score: 6
Sun Mar 17 20:11:28 2024 kern.notice kernel: network configuration has been changed
Sun Mar 17 20:11:29 2024 kern.notice kernel: mwan3 configuration has been changed
Sun Mar 17 20:11:33 2024 daemon.notice netifd: Wireless device ‘radio0’ set retry=3
Sun Mar 17 20:11:33 2024 daemon.notice netifd: Interface ‘wan’ is enabled
Sun Mar 17 20:11:33 2024 daemon.notice netifd: Interface ‘wan’ has link connectivity
Sun Mar 17 20:11:33 2024 daemon.notice netifd: Interface ‘wan’ is setting up now
Sun Mar 17 20:11:34 2024 daemon.notice netifd: wan (18247): udhcpc: started, v1.34.1
Sun Mar 17 20:11:34 2024 daemon.notice hostapd: wlan0: AP-STA-DISCONNECTED a6:59:78:af:45:09
Sun Mar 17 20:11:34 2024 kern.notice Freddies Wifi: WiFi client disconnected: A6:59:78:AF:45:09
Sun Mar 17 20:11:35 2024 daemon.notice netifd: wan (18247): udhcpc: broadcasting discover
Sun Mar 17 20:11:35 2024 daemon.notice netifd: wan (18247): udhcpc: broadcasting select for 192.168.88.254, server 192.168.88.1
Sun Mar 17 20:11:35 2024 daemon.notice netifd: wan (18247): udhcpc: lease of 192.168.88.254 obtained from 192.168.88.1, lease time 600
Sun Mar 17 20:11:36 2024 daemon.notice netifd: Interface ‘wan’ is now up
Sun Mar 17 20:11:36 2024 daemon.info dnsmasq[14756]: reading /tmp/resolv.conf.d/resolv.conf.auto
Sun Mar 17 20:11:36 2024 daemon.info dnsmasq[14756]: using only locally-known addresses for domain test
Sun Mar 17 20:11:36 2024 daemon.info dnsmasq[14756]: using only locally-known addresses for domain onion
Sun Mar 17 20:11:36 2024 daemon.info dnsmasq[14756]: using only locally-known addresses for domain localhost
Sun Mar 17 20:11:36 2024 daemon.info dnsmasq[14756]: using only locally-known addresses for domain invalid
Sun Mar 17 20:11:36 2024 daemon.info dnsmasq[14756]: using only locally-known addresses for domain bind
Sun Mar 17 20:11:36 2024 daemon.info dnsmasq[14756]: using only locally-known addresses for domain lan
Sun Mar 17 20:11:36 2024 daemon.info dnsmasq[14756]: using nameserver 192.168.88.1#53
Sun Mar 17 20:11:36 2024 daemon.info dnsmasq[14756]: using nameserver 82.132.254.2#53
Sun Mar 17 20:11:36 2024 daemon.info dnsmasq[14756]: using nameserver 82.132.254.3#53
Sun Mar 17 20:11:36 2024 daemon.info dnsmasq[14756]: using nameserver 192.168.50.1#53
Sun Mar 17 20:11:38 2024 user.notice firewall: Reloading firewall due to ifup of wan (eth1)
Sun Mar 17 20:11:41 2024 daemon.info hostapd: wlan0: STA a6:59:78:af:45:09 IEEE 802.11: authenticated
Sun Mar 17 20:11:41 2024 daemon.info hostapd: wlan0: STA a6:59:78:af:45:09 IEEE 802.11: associated (aid 1)
Sun Mar 17 20:11:41 2024 daemon.notice hostapd: wlan0: AP-STA-CONNECTED a6:59:78:af:45:09 auth_alg=open
Sun Mar 17 20:11:41 2024 kern.notice Freddies Wifi: WiFi client connected: A6:59:78:AF:45:09
Sun Mar 17 20:11:42 2024 daemon.info hostapd: wlan0: STA a6:59:78:af:45:09 RADIUS: starting accounting session CF22B8130D3FF6EB
Sun Mar 17 20:11:42 2024 daemon.info hostapd: wlan0: STA a6:59:78:af:45:09 WPA: pairwise key handshake completed (RSN)
Sun Mar 17 20:11:42 2024 daemon.notice hostapd: wlan0: EAPOL-4WAY-HS-COMPLETED a6:59:78:af:45:09
Sun Mar 17 20:11:42 2024 daemon.info dnsmasq-dhcp[14756]: DHCPREQUEST(br-lan) 192.168.1.152 a6:59:78:af:45:09
Sun Mar 17 20:11:42 2024 daemon.info dnsmasq-dhcp[14756]: DHCPACK(br-lan) 192.168.1.152 a6:59:78:af:45:09
Sun Mar 17 20:11:46 2024 daemon.info dnsmasq[14756]: exiting on receipt of SIGTERM
Sun Mar 17 20:11:46 2024 daemon.info dnsmasq[18779]: Connected to system UBus
Sun Mar 17 20:11:46 2024 daemon.info dnsmasq[18779]: started, version 2.85 cachesize 150
Sun Mar 17 20:11:46 2024 daemon.info dnsmasq[18779]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-regex no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-cryptohash no-DNSSEC no-ID loop-detect inotify dumpfile
Sun Mar 17 20:11:46 2024 daemon.info dnsmasq[18779]: UBus support enabled: connected to system bus
Sun Mar 17 20:11:46 2024 daemon.info dnsmasq-dhcp[18779]: DHCP, IP range 192.168.1.100 – 192.168.1.249, lease time 12h
Sun Mar 17 20:11:46 2024 daemon.info dnsmasq[18779]: using only locally-known addresses for domain test
Sun Mar 17 20:11:46 2024 daemon.info dnsmasq[18779]: using only locally-known addresses for domain onion
Sun Mar 17 20:11:46 2024 daemon.info dnsmasq[18779]: using only locally-known addresses for domain localhost
Sun Mar 17 20:11:46 2024 daemon.info dnsmasq[18779]: using only locally-known addresses for domain invalid
Sun Mar 17 20:11:46 2024 daemon.info dnsmasq[18779]: using only locally-known addresses for domain bind
Sun Mar 17 20:11:46 2024 daemon.info dnsmasq[18779]: using only locally-known addresses for domain lan
Sun Mar 17 20:11:46 2024 daemon.info dnsmasq[18779]: reading /tmp/resolv.conf.d/resolv.conf.auto
Sun Mar 17 20:11:46 2024 daemon.info dnsmasq[18779]: using nameserver 192.168.88.1#53
Sun Mar 17 20:11:46 2024 daemon.info dnsmasq[18779]: using nameserver 82.132.254.2#53
Sun Mar 17 20:11:46 2024 daemon.info dnsmasq[18779]: using nameserver 82.132.254.3#53
Sun Mar 17 20:11:46 2024 daemon.info dnsmasq[18779]: using nameserver 192.168.50.1#53
Sun Mar 17 20:11:46 2024 daemon.info dnsmasq[18779]: read /etc/hosts - 4 addresses
Sun Mar 17 20:11:46 2024 daemon.info dnsmasq[18779]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Sun Mar 17 20:11:46 2024 daemon.info dnsmasq-dhcp[18779]: read /etc/ethers - 0 addresses
Sun Mar 17 20:11:50 2024 user.notice mwan3track[15444]: Stopping mwan3track for interface “mob1s1a1”. Status was “online”
Sun Mar 17 20:11:50 2024 user.notice mwan3track[15445]: Stopping mwan3track for interface “ifWan1”. Status was “online”
Sun Mar 17 20:11:54 2024 user.notice mwan3-hotplug[19062]: Execute ifup event on interface wan (eth1)
Sun Mar 17 20:11:54 2024 user.notice mwan3-hotplug[19070]: Execute ifup event on interface mob1s1a1 (qmimux0)
Sun Mar 17 20:11:55 2024 user.notice mwan3-hotplug[19084]: Execute ifup event on interface ifWan1 (wlan0-1)
Sun Mar 17 20:11:58 2024 daemon.err dnsmasq[18779]: failed to send packet: Network unreachable
Sun Mar 17 20:11:59 2024 daemon.err dnsmasq[18779]: failed to send packet: Network unreachable
Sun Mar 17 20:12:01 2024 daemon.err dnsmasq[18779]: failed to send packet: Network unreachable
Sun Mar 17 20:12:05 2024 daemon.err dnsmasq[18779]: failed to send packet: Network unreachable
Sun Mar 17 20:12:05 2024 user.notice mwan3track[19542]: Interface wan (eth1) is online
Sun Mar 17 20:12:05 2024 user.notice mwan3track[19543]: Interface mob1s1a1 (qmimux0) is online
Sun Mar 17 20:12:05 2024 user.notice mwan3track[19544]: Interface ifWan1 (wlan0-1) is online
Sun Mar 17 20:12:11 2024 user.info mwan3track[19542]: Check (ping) failed for target “1.1.1.1” on interface wan (eth1). Current score: 6
Sun Mar 17 20:12:13 2024 user.info mwan3track[19542]: Check (ping) failed for target “8.8.8.8” on interface wan (eth1). Current score: 6
Sun Mar 17 20:12:13 2024 daemon.info dnsmasq[18779]: read /etc/hosts - 4 addresses
Sun Mar 17 20:12:13 2024 daemon.info dnsmasq[18779]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Sun Mar 17 20:12:13 2024 daemon.info dnsmasq-dhcp[18779]: read /etc/ethers - 0 addresses
Sun Mar 17 20:12:13 2024 user.notice mwan3track[19542]: Interface wan (eth1) is disconnecting
Sun Mar 17 20:12:23 2024 user.info mwan3track[19542]: Check (ping) failed for target “1.1.1.1” on interface wan (eth1). Current score: 5
Sun Mar 17 20:12:25 2024 user.info mwan3track[19542]: Check (ping) failed for target “8.8.8.8” on interface wan (eth1). Current score: 5
Sun Mar 17 20:12:30 2024 user.info mwan3track[19542]: Check (ping) failed for target “1.1.1.1” on interface wan (eth1). Current score: 4
Sun Mar 17 20:12:33 2024 user.info mwan3track[19542]: Check (ping) failed for target “8.8.8.8” on interface wan (eth1). Current score: 4
Sun Mar 17 20:12:33 2024 user.notice mwan3track[19542]: Interface wan (eth1) is offline
Sun Mar 17 20:12:34 2024 user.info mwan3-hotplug[20496]: Connection tracking flushed for interface ‘wan’ on action ‘disconnected’
Sun Mar 17 20:12:34 2024 user.notice mwan3-hotplug[20496]: Execute disconnected event on interface wan (eth1)
Sun Mar 17 20:13:22 2024 user.info mwan3track[19543]: Check (ping) failed for target “1.1.1.1” on interface mob1s1a1 (qmimux0). Current score: 6
Sun Mar 17 20:13:31 2024 user.info mwan3track[19543]: Check (ping) failed for target “1.1.1.1” on interface mob1s1a1 (qmimux0). Current score: 6
Sun Mar 17 20:13:33 2024 kern.notice Password auth succeeded for admin on HTTP from
Sun Mar 17 20:13:33 2024 daemon.err uhttpd[2496]: vuci: accepted login for admin from
Firmware is latest version.
