I have updated a RUT950 from 00.07.04.5 to 00.07.05 firmware.
All is working fine, but in Services - VPN - Client it seems to be disconnected from the OpenVPN that I’m currently using, but it’s not really disconnected, I’ve got IP from VPN and, as I says, all works properly but a pop up appears saying “failed to load VPN status” and logs won’t help.
Any suggestion?
Antonio
I assume you updated the device with ‘keep settings’ option enabled. If the VPN and everything else works, you can ignore the message. However, I would recommend restoring the device to factory defaults and reconfiguring it. The WebUI now shows information about the VPN connection, so it is possible that there were issues migrating your configurations from the previous firmware version.
