When I try to configure my WAN settings with the static IP etc. I have from my ISP I am not able to save & apply. there is no remarks or errors showing up, simply nothing happens when I press the button.
I’ve tried via different browsers and also both from Http and Https.
You cannot set a static public IP address yourself; it is determined and provided by your ISP. Typically, obtaining a static public IP address is an additional service offered by your ISP.
I use a similar setup, but no ISP. A static WAN and pointing to a firewall, but I can’t save the configuration either with the new firmware. Older firmware is running that setup without problem.
I’m sorry for any trouble this has caused. Our team knows about the problem and is working on fixing it. We’re on it and you can expect it to be sorted out in the next updates. Thanks for being patient.
