RUT950 on Cloudconnexa
i use a 950 router on CLOUDCONNEXA service using TK 950 as connector (OPENVPN)
internal ip of router is 192.168.0.60
1 the Cloudconnexa CONNECTOR is connected correcty on cloudconnexa portal ( light green)
2 cloudconnexa assigned remote client subnet is 100.96.1.xx and also the CONNECTOR ip for rut950 is 100.96.1.29
3 my pc office subnet is 192.168.0.0
internal gw is 192.168.0.1 route on internal gw is set a route to 100.96.1.xx with gw 192.168.0.60
4 wen remote client is connected to cloudconnexa portal are assigned an ip for example 100.96.1.12
now I CAN PING from a local pc 192.168.0.5 to 100.96.1.12
now I CAN PING from pc 192.168.0.5 To 100.96.1.29
but I CAN NOT ping from 100.96.1.12 to 192.168.0.60
or CAN NOT ping from 100.96.1.12 to 192.168.0.5 or any other pc or device of internal subnet
i have try to set on vpn settings of rut950
push route " 192.0.0.0. 255.255.255.0"
but when i confirm hang i CANNOT login the web administrator of rut950 i have to hardware reset last backup o configuration also if the vpn with cloudconnexa is still up
all are fully functional until last week the i then I stupidly reset the configuration of rut950 aand I am no longer able to redo the correct configuration
any help
