Hi folks, I absolutely need to install OSPF in a group of RUT950. These routers haven’t any optional package on board but it seems that flash memory is not enough to install the package I need. Is there any chance/trick/magic to do that? Thanks
Hi…
Did you look at https://wiki.teltonika-networks.com/view/RUT950_Package_Downloads
There is a OSPF
https://opkg.teltonika-networks.com/e3f1651748814ded9771ec75341fa86b7a9f80f0a1853a686bd70bca4b74bdce/wiki/ospf_daemon.tar.gz
And dynamic routing (rut950)
https://wiki.teltonika-networks.com/view/RUT950_Routing
There is a chapter about OSPF.
Hi Marcelo,
thanks for the quick answer :), I already know the page you show me, but the problem is that I can’t install the package because, as you can see on the list, its size is 1.51 MB and I have only 1.4 MB free on the router flash, without any optional package installed and the latest firmware RUT9_R_00.07.06.17
Have you see this url?
du -a / 2>/dev/null | sort -n -r | head -n 40
Also… Remove log from the device
Sample…
View space at the flash
command df
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/root 9600 9600 0 100% /rom
tmpfs 30072 328 29744 1% /tmp
/dev/mtdblock6 4416 452 3964 10% /overlay
overlayfs:/overlay 4416 452 3964 10% /
/dev/mtdblock7 576 312 264 54% /log
tmpfs 512 0 512 0% /de
cd /log/
ls -l
-rw-r–r-- 1 root root 444416 Feb 2 17:55 log.db
-rw-r–r-- 1 root root 129 Apr 14 2023 rms_id
-rw-r–r-- 1 root root 4 Jan 27 15:51 sim_1_pin
rm log.db
df
tmpfs 30072 372 29700 1% /tmp
/dev/mtdblock7 576 332 244 58% /log
tmpfs 512 0 512 0% /dev
ls -l
-rw-r–r-- 1 root root 0 Feb 2 17:56 log.db
Updating…
I found this command
opkg list-installed | awk ‘{print $1}’ | while read -r line; do if (opkg info $line | grep -q ‘install ok
installed’); then opkg --autoremove remove $line; fi; done
And last…
Try to remove at Package Manager.. To clean some packets?
Hi Marcelo, thanks again. Cheking with WinSCP, it seems that I haven’t bigger files, now I’m trying to remove logs, I’ll let you know.
Hello @Antonio,
Could you please confirm if your topic has been resolved, or do you still need any assistance with this?
Hi, the issue was solved deleting the default configuration on the router. Now memory space is enough for OSPF uploading. Thanks.
