Rut950 no access to Web UI possible
Hi, since September this year I can’t reach my Rut950 Web UI. It’s neither possible via WLAN nor LAN. In the meantime I reset the router. Now I have the factory settings again. The router continues to set up a WLAN network but it is not possible to log into the user interface.
The error message is: “Unable to launch the requested CGI program:
/www/cgi-bin/luci: Input/output error”
Does anyone have a solution for this problem?
Thank you for reaching out.
Could you let me know what WiFi SSID the router is currently showing?
Furthermore, if you haven’t tried this yet, performing a firmware installation through the Bootloader menu may be useful to give it a try.
Please let me know how it goes or if you need further assistance with this.
Hello, thank you for the quick reply.
I had to perform the reset twice as described in the bootloader menu. Then I installed the firmware.
It worked! Thank you!
