I have a RUT950 with the latest firmware (RUT9_R_00.07.06.17), but I always get Internal modem is not reachable.
The SIM card is not recognised.
Factory reset and downgrade to older firmware does not change anything.
How can i bring the device back online?
Execute lsusb
in CLI and share response,
Here are the result
BusyBox v1.34.1 (2025-01-06 06:06:30 UTC) built-in shell (ash)
____ _ ___ ____
| _ \ _ _| |_ / _ \/ ___|
| |_) | | | | __| | | \___ \
| _ <| |_| | |_| |_| |___) |
|_| \_\\__,_|\__|\___/|____/
Teltonika RUT9 series 2025
Device: RUT950
Kernel: 5.4.259
Firmware: RUT9_R_00.07.06.17
Build: a4aefd8a170
Build date: 2025-01-06 07:09:12
root@RUT950:~# lsusb
Bus 001 Device 001: ID 1d6b:0002
Bus 001 Device 005: ID 05c6:f601
root@RUT950:~#
Unfortunately, based on the output, it appears that the modem is not recoverable. The only available option is to send the device for repair through the RMA process. Please contact your reseller for further assistance and details.
ok. We do not know the reseller.
Is this error within the RMA or must the device still be under warranty?
SN: 1117030219
To proceed with an RMA, the device must be under warranty. After checking, I found that unfortunately, your device’s warranty expired on 2024-03-21.
Additionally, please avoid sharing sensitive information such as the device serial number on public forums, as it may pose a security risk.
Ok, so the device is now electronic waste.
What a pity
We can assist you in recycling the device in an environmentally friendly manner. However, you will need to contact your reseller first.
You mentioned that you do not know the reseller—could you please let us know where you originally obtained the device?
