I have an RUT950 router in my Concorde motorhome. The router was installed when I bought the motorhome and is Concorde-branded (Label) The router also does not have the Teltonika user interface but a Concorde user interface (Operaating System?). I would like to install the latest firmware for the RUT950 with the official firmware from Teltonika. Is this possible and what is the procedure for overwriting the branded version?
Since you are using a branded firmware version, we cannot guarantee that overwriting the firmware will work, however you can still give it a try.
If the firmware that you are using is Linux-OpenWRT based, there is a possibility that updating the firmware will work via the use of the command line.
I would like to give some feedback here for anyone who is interested. Firstly, I carried out a factory reset. Then I installed the latest available legacy firmware on the router (6.09.5) using the bootloader functionality. I then configured the router and installed the latest firmware 7.06.10 via the web interface. This all worked without any problems.
