RUT950 can't connect to Internet but Wifi connection is Ok
Hi, my RUT950 which is connected to Wifi to be connected ethernet to PC. but suddenly the internet connection is not connected after 1 month of good connection. I use DHCP for my PC thqt connected with router.
I have checked the wifi network that my router gets and it is good. here I include the troubleshoot file. Thank you.
Hi niamiun,
I would like you to check a few things:
  1. Which firmware is your device running? Check here if yours is on the latest FW version.
  2. Go to Network → Wireless → SSIDs. Check if Wi-Fi Client status is connected. Then check in WAN if wifi interface status is up.
  3. Make sure that LAN IP and WAN IP does not overlap to avoid IP conflicts.
  4. Have you configured anything else apart from Wi-Fi (VLANs, Firewalls)?
Let me know if this helps.
