Hi, I’m using an RUT906 with the impulse counter (on pins 2&7) and sending the value via MQTT. This is working but I only get the impulse count every 60 seconds. The MQTT message is set to send every 10 seconds. Is there anyway to decrease the interval to get the impulse count every 10 seconds? We are trying to use it for RPM measurement so would like to match the 10s on the MQTT data.
